Hi guys
Not sure if i posted in correct section, but my ODO seems to be reading incorrectly for the traveled KM's
I've tested it this week and so far half tank has gotten me 78KMs?
I don't think its my fuel efficiency as my car hardly has anything that would use that much petrol when driving normally
I was expecting at least 150 - 200 on half tank reading but its sitting on 82KM traveled at the moment
Any help would be appreciated
Cheers,
Will
https://www.sau.com.au/forums/topic/296632-odo-doesnt-accumuate-kms-accurately/
Odometer measures distances, not fuel economy.
Poor fuel economy is often the result of a failed engine temp sensor (ECU thinks the engine is still cold, and overfuels the mixtures).
Other possibility is a dirty air filter restricting airflow into the engine.
Yes i know it measures the distance but is it possible for it to read inaccurately?
I will be getting my car checked out this week, will be running it on my mates dyno to see if the ODO matches up with the dyno distance traveled
I'll get the engine temp sensor checked as well, other then that any other possibilities?
What I'm saying is that just because you have used more fuel than you expected to use doesn't mean the odometer is inaccurate. Presumably it has been accurate until now, so there is no reason why it would suddenly become inaccurate.
And it's "other THAN that".
Fair enough, I'll see how it goes this Saturday
Hopefully its something as simple as the O2 sensor or Engine temp sensor
... but my ODO seems to be reading incorrectly for the traveled KM's
Cheers,
Will
What blind_elk is saying is that there has to be something else other than just the odometer that's at fault.
If you're using up half a tank to get as far as 78Kms, something abominable is going on (according to your fuel gauge + tripmeter + calculations of where you've travelled).
2 faults = 2 different sets of symptoms in this case
Yeah at the moment I'm still trying to see what else is going on, taking into account everyone's suggestions as well
I wont know until i have it checked out this Saturday, i just thought it was strange as my driving style hasn't changed and i feel i have traveled more then 80KM this week (Liverpool to Wollongong on Saturday which should have yielded at least 80kms on top of whatever i already had).
But yeah look will keep you guys posted on this.
Thanks for your help
Update!
Got it checked out and it was the ODO reading incorrectly (half of what its meant to read)
I just got the SINE WAVE box re calibrated so all is reading correctly.
Thanks for your help guys
Update!
Good stuff Grimmjow. Bet you feel vindicated that it WAS the ODO :-)
haha im having the same problem with my stock one, and the speedo is half of what it should be :\ maybe i need to get it calibrated? Dunno getting a new cluster and gear sensor this weekend
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
