This guide is targeted for people who want to watch their movies on their Nintendo DS.Many people maybe wonder about what is dpg or dpg formats. DPG is a Nintendo DS Movie File. .DPG files stand for Nintendo Dual screen .MPEG video format, which is a kind of MPEG-1 video created by Moonshell for Nintendo Dual Screen. All DPG files contain a 36 byte header, followed by audio, and then a standard mpeg-1 video stream.
To Open DPG file on Windows, the following three ways are recommended.
BatchDPG
Moonshell
DPG Player
Now, I begin to explain my article step by step. I divide this article into two parts:
Part 1. How to put dvd on NDS or IDS DPG
Part 2. How to put video on DPG
Part 1: How to put DVD on NDS or IDS DPG with 4Videosoft DVD to DPG Converter
Step 0: Download and install 4Videosoft DVD to DPG Converter. When you finished the download process, run the .exe file to install it. Its interface will be shown as the following.
Step 1: Load your DVD
Place the DVD into your DVD drive and click the “Load DVD” button to load your souce DVD. You can load your DVD, DVD folder, and also IFO file.
Step 2. Choose your output profile and settings
At the lower part of the interface you can find a "Profile" drop-down list, you can find one for yourself.
Click "Settings" on the right side of "Profile" you can adjust your output's settings, such as "Resolution", "Frame Rate", "Bitrate" and so on.
Step 3. Start Conversion
If you don't want any more editing, just Click "START" button to start your conversion.
Tips:
1.Effect
Click "Effect" button you can adjust brightness, contrast, saturation and volume easily.
2.Trim
If you want to cut your DVD movie into many different parts, or you just want to convert one part of the movie, just use “Trim” function.
3 methods for you to complete this:
a. Drag the slider
b. Click “Start Time” and “End Time” button
c. Set the value
3.Crop
"Crop" function allows you to remove the black edges and customize the aspect ratio
3 ways for your to do this.
a. Selecting the crop mode
b. adjusting the crop frame
c. setting the crop value
You can customize the your own aspect ratio using "Zoom Mode". It provides you "Keep Original", "Full Screen", "16:9" and "4:3".
4.Merge and Snapshot
"Merge" function enables you to put many chapters into one output video file
"Snapshot" allows you to capture the picture of the movie you like
5.Audio Track and Subtitles
You can choose the audio track and subtitles before conversion (If your DVD has different audio track and subtitles).
Part 2. How to convert videos to DPG video format with 4videosoft DPG Converter
Preparation: Download 4videosoft DPG Converter and double click the .exe file to run it.
Step 1. Import your video
Click “Add File” or “File” button to load your video from your computer or other hard drive.
Step 2: Video settings.
Select the output video format you want from the “Profile” drop-down list.
Step 3: Place video
Click “Open Folder” button to open your output destination file.
Step 4: Start conversion
Click the “START” button to start your conversion and in a short while it will be finished.
For you to better enjoy your video on Nintendo, 4Videosoft DPG Converter provides you more valuable editing functions of “Trim, Effect, Crop, Snapshot and Merge into one file”. Then you can adjust output video effect, capture any video clips and customize the output play region. For you to get the exact file, more specific parameters are available for you to set.
Now it’s your turn to enjoy your favorite movies with this powerful software.
Sony XPERIA Video Converter
Cell Phone Video Converter
MKV Video Converter
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
