Thinking about adapting an 'new' R34 GTR engine loom to an R32 GTR. Can anyone shed light on the differences? I know the R34 CAS is different, and for example you can't use an R34 Power FC on a 32 or 33 but not sure if this is because of the pin outs, the CAS (different on the R34) or if the whole lot is totally different.
Being an RB26 I'd have thought an R34 loom could be made to fit with a few changes.
Cheers
https://www.sau.com.au/forums/topic/296671-r34-gtr-vs-r32-gtr-engine-loom/
there is a lot of differences, the r34 picks all its power from in the car R32 takes it from behind lh headlight recess. its easier to retro fit r32 stuff onto r34 engine.
You could if you were patient swap all the electronic engine control gear from the r34 engine loom onto the r32 engine loom but only utilize the body / wiper / power portion.
I have done it all before (in our s13 i did the above so that it all plugged in as per factory) i have also done a R32 rb26 into S15 the same way but its ALOT of time and effort, especially in your case as the only benefit is internal igniter.
Edited by URAS
Thanks Trent
You mean retain the body/wiper/power portion of the R32 loom? I received this from Ray Hall re using my R32 V44 board:
The same plug-in ECU is used on the R32 and R34 GTR. There is a jumper on the base board that selects either model. So based on this you can use the R34 harness. I have no idea how this harness will connect to the engine, but the ECU end is correct.
Cheers
my R32 GTR runs a 34 N1 Nur engine inc the 34 CAS etc. I will have to have a look and see how it's done. it all looks factory. I had it done in japan so I have NFI exacly how they did it. I'll have a look and see what coil packs it's running too.
it would just be a pin swap for the cas, nice and simple.
I have reread the post from scooby again and im a bit confused now. I though he wanted to run a r34 engine loom.
maybe he can clear this up and post exactly why he want so use a r34 loom. cause if it is just the CAS issue its a 2min fix with some tweezers :D
Thanks Trent and Richard
It's the R34 GTR engine loom I want to use. No problems yet, but 17 yo heat soaked wiring being what it is I'm looking to replace it, particularly since I already have the 34 loom.
Excellent point re the coil packs, hadn't considered them yet. I seem to remember they are different to 32/33. Look forward to hearing about that.
Cheers
Mark
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
