WHAT?!?!?
You gotta be kidding me right?
We used the same shit at my old work (different brand but looks 100% the same as the stuff im seeing in these pics) to do a bunch of cars, can get it in all different colours, black, silver, blue, red, yellow etc. We bought a few rolls of all different colours (a roll was like 30m) and ended up doing a few cars sub boxes, door inserts (including my own) and for 3 rolls of the stuff i dont remember us paying anywhere near that!
F**k paying that much for vinyl, my god.
Like you said, "different brand", so that's the difference in price.
With the 3M vinyl, it's NOT all about the looks and appearance of it, it's also about the technology they used in the vinyl to ensure that there's no air bubbles.
On the sticky side of the vinyl, theres a grid pattern that's been cut/scored, so if theres air bubbles, you can just push the air through the cut grid and out to the edges.
Unique Comply™ Technology 3M DI-NOC™ Film uses an adhesive system with grid-like channels on the adhesive surface, allowing air to escape during application. Air bubbles trapped between the material and the film can escape along these tracks, making applications to a large and complicated surface easier and ensuring a perfect finish.
  • Replies 477
here you go :rofl:
nice man,
i haven't been one for the clear coat side of things, but i have a feeling that the exterior work would look nicer with a clear coat on it, i dont know why, but just a thought, either way nice job
If only you were in QLD :D
Id love to get the wing stands and pillars done.
Loving the stands on Ashneel's 34
If you don't mind the hassle, you can send them down to me and I'll wrap it and post it back to you for $60+postage back to you :(
But with pillars, I'm sure you can wrap it yourself, I could send you down 2 strips that's enough to wrap both pillars for $40 :banana:
Damn, you're doing all the bits I've been wanting / pining on doing since i saw them on Import Monster ..
I really need to talk to you about getting like a roll or enough to do all my interior bits, sedan b-pillars (twice as much as coupes), etc.
I've just about given up trying to get it through the distributors themselves...
i hate you so bad charles lol, im gonna have to suck it up and just buy some already haha, i have no doubt that everything you cover will be what i wantd to do as well
Hahahaha! Do you wanna give me your postal address? So I can send you a little sample to tease you even more? :blink:
And I'm being serious too lol, I've got a few little off cuts :down:
  • 3 weeks later...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
