  • Replies 477
whats the best way to do a join, for a bonnet, my R33 bonnet is too big and would need to pieces, any hint or tips, DRIFTT, wanna do my bonnet for a carton of corona???
Lay one in a straight line then place second one next to it............ Not as simple as that but other things like temp come into account.
F#&K that and it is better with 2 or 3 people and if that cheap shit I would not look at doing any job with it.
Edited by Guest
i saw u replied in that for sale thread of his. thought it was too cheap to be true,
Charles I'm waiting for you to do a full gainer on the whole car, excellent work on the Z.
Haha thanks :P but a whole will never happen :)
looks ok
Looks ok only in certain angles, at other angles, the coated just looks like gloss black.
hey just wondering what this stuff is like to use? is it similar to an avery 700 series or thicker like a reflective media? and how long is it rated (3yrs) ?
This vinyl will go soft when heated, so you can work it around corners and stuff.
3M gurantees 4yrs lifespan outdoor with UV protection
It is nothing like normal cast vinyl but if you have used it a fair bit or done vehicle wraps it helps.
will this stuff loosen on hot days?
say you heated it to strech around something, if it gets hot one day will it come loose?
If you have curves and the correct primer isn't used, yes it will come loose. You have to take your time not stretching it to much and bring those bubbles out before you fit the bits.
Ah k so its a calendered polymeric film. fark must take ages to get it to conform around those small curves, i just want to do boot and bonnet so shouldnt be hard.
Driftt do you work in a sign shop? Im looking at wrapping my car matte black and need to source some vinyl. Spandex, qual sign and robayne pretty pricey over the counter.
One issue with clear coating people forget is that there is movement of the material so on items that might flex the coating will crack, just a point as to why it isn't clear coated.
Message me your details, what you are after and will see what I can do to help you out.
Edited by Guest
Hi Charles, awesome works you've done here! I'd like to get some of those CF vinyl to try on my car. I couldn't pm u coz I havent had enough post yet. Anyway, can you give me a quote and it's gonna be good if I can pick it up next week. I'll hav whole week next week off to play with it. Thanks!
Ever since i saw DRIFTT's pic of a dash being wrapped, I also wanted to wrap mine. How much do you guys reckon it would take to wrap a whole 180sx dash? My dash has a few small cracks and I want to replace it or wrap it in this stuff. Even if this is more expensive then just replacing the dash, I'd rather go with the carbon look.
I have a whole load of Nissan bits coming in from a mate, he will be doing it on a direct exchange basis with the Carbon Wrapped parts sitting on the shelf ready, started doing them already to build the stock up. Looking at S13, S14, R32, R33 and some other one's not 100% sure. Since you have to use a primer you can use lower grade parts which of course are worth less so even though wrapped the cost isn't much higher then A grade parts.
Got a complete AE86 trim to do now for same guy, better to repair cracks and just wrap it compared to tracking down a new/decent replacement dash.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
