  • Replies 477
whats the best way to do a join, for a bonnet, my R33 bonnet is too big and would need to pieces, any hint or tips, DRIFTT, wanna do my bonnet for a carton of corona???
Lay one in a straight line then place second one next to it............ Not as simple as that but other things like temp come into account.
F#&K that and it is better with 2 or 3 people and if that cheap shit I would not look at doing any job with it.
Edited by Guest
i saw u replied in that for sale thread of his. thought it was too cheap to be true,
Charles I'm waiting for you to do a full gainer on the whole car, excellent work on the Z.
Haha thanks :P but a whole will never happen :)
looks ok
Looks ok only in certain angles, at other angles, the coated just looks like gloss black.
hey just wondering what this stuff is like to use? is it similar to an avery 700 series or thicker like a reflective media? and how long is it rated (3yrs) ?
This vinyl will go soft when heated, so you can work it around corners and stuff.
3M gurantees 4yrs lifespan outdoor with UV protection
It is nothing like normal cast vinyl but if you have used it a fair bit or done vehicle wraps it helps.
will this stuff loosen on hot days?
say you heated it to strech around something, if it gets hot one day will it come loose?
If you have curves and the correct primer isn't used, yes it will come loose. You have to take your time not stretching it to much and bring those bubbles out before you fit the bits.
Ah k so its a calendered polymeric film. fark must take ages to get it to conform around those small curves, i just want to do boot and bonnet so shouldnt be hard.
Driftt do you work in a sign shop? Im looking at wrapping my car matte black and need to source some vinyl. Spandex, qual sign and robayne pretty pricey over the counter.
One issue with clear coating people forget is that there is movement of the material so on items that might flex the coating will crack, just a point as to why it isn't clear coated.
Message me your details, what you are after and will see what I can do to help you out.
Edited by Guest
Hi Charles, awesome works you've done here! I'd like to get some of those CF vinyl to try on my car. I couldn't pm u coz I havent had enough post yet. Anyway, can you give me a quote and it's gonna be good if I can pick it up next week. I'll hav whole week next week off to play with it. Thanks!
Ever since i saw DRIFTT's pic of a dash being wrapped, I also wanted to wrap mine. How much do you guys reckon it would take to wrap a whole 180sx dash? My dash has a few small cracks and I want to replace it or wrap it in this stuff. Even if this is more expensive then just replacing the dash, I'd rather go with the carbon look.
I have a whole load of Nissan bits coming in from a mate, he will be doing it on a direct exchange basis with the Carbon Wrapped parts sitting on the shelf ready, started doing them already to build the stock up. Looking at S13, S14, R32, R33 and some other one's not 100% sure. Since you have to use a primer you can use lower grade parts which of course are worth less so even though wrapped the cost isn't much higher then A grade parts.
Got a complete AE86 trim to do now for same guy, better to repair cracks and just wrap it compared to tracking down a new/decent replacement dash.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
