  • Replies 477
Well I have started cutting DI-NOC as you can see by the wood grain iPhone covers, isn't simple and takes a bit of time but perfect cut.
This stuff is as thick as the carbon but smoother so trying the carbon in next few days, let the fun begin.
Edited by Guest
  • 3 weeks later...
Just had a thought of how cool my cordless mouse would look for my laptop. Feel stupid asking this from the amount of stuff iv seen wrapped here... Is it possible? with the fine button lines n all?
Show me a pic and I'll tell you :whistling:
Here's one for you that is a bit different............. The start of a large Jet Ski.
looks good,
well done with the curves, got a lil project of my own some of you might be interested in, will post pics soon
Link:
http://www.maplin.co.uk/images/Full/a84hx.jpg
If you thinks its easy to do ill give it a burl, would look good i think, then i'd like to put a small GTT logo where it says logitech.
Are you wrapping the whole thing or just a certain part?
But I think it shouldn't be too hard as long as you have patience. PM ne if you need a little sheet of the vinyl.
Hey mate, saw your'e in Mordy, I live pretty close :D. Really interested in getting this done for my head unit surround thingy and some other places. Since i'm a poor P-plater price is a big deal :D. I cant send a pm because i'm still new sorry.
looks good,
Thanks, second one came out a lot better as you can see and Version 2.0 of the iPhone cover is on the streets.
Also got a complete R33 trim set to use on an exchange basis over here as a pain rushing.
Hey mate, saw your'e in Mordy, I live pretty close :). Really interested in getting this done for my head unit surround thingy and some other places. Since i'm a poor P-plater price is a big deal :D. I cant send a pm because i'm still new sorry.
No problem mate, gimme a buzz or sms on 0434 502 855 :D
Thats the bees knees, nice work guys.
I'm trying to find this stuff in matte black, no luck so far. :thumbsup:
I can get hold of it in Matt Black just depends on what you want it for as to worth getting or not.
driftt or charles, could you do a GTR plenum??
Yeah easy just need one to give it a go.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
