So is this the recognised best product for external use?
My R34 4-door's passenger side B-pillar factory carbon vinyl is very sun-damaged, and needs to be replaced, but I'm not sure what is the best UV/weather resistant product to use?
I'm in Adelaide, so any supplier references would be good also.
  • Replies 477
Well, if you want, you could send your b pillar to me and I can wrap it for you :P
OR I could send you 2 strips of vinyl and you can wrap it urself :D
I'm in Adelaide with an R34 4-door with the exact same issue (sun-damaged factory carbon vinyls)... I've been recently in contact with a local seller of DI-NOC, but I'm still waiting a call-back from them.
I'm honestly not really looking forward to tackling fixing it - I don't know whether the pillars remove like in coupes - and I'm gonna have to try and remove the factory wind deflectors too (without destroying them!).
I'll let you know if they get back to me (they were a reference from the 3M DI-NOC website for retailers in SA).
Well if you just need the vinyl to fix your pillars, then I'm sure I can sell you some cheaper than they can ;)
Lemme know how much they wanna charge you.
using any printed vinyl like those B-pillar nismo stickers will always fade badly if you leave the car in daylight alot...
If this stuff has a texture to it I can imagine using it externally it could collect dirt and grime and be annoying to when washing the car...
real carbon fibre items are the only way to have a long lasting trouble free reality...
Well if you just need the vinyl to fix your pillars, then I'm sure I can sell you some cheaper than they can :D
JRM: I'll be very interested in the results of your research :P could you send me a PM when they get back in contact with you, in case I forget to check this thread, lol.
I don't expect the actual process to be especially difficult. I've had a look, and the factory vinyl is directly applied to the steel door frame. I believe that a careful approach with a heat gun (hair dryer if you need) to avoid damaging the adjacent rubber seals will allow the old vinyl to be peeled off. A new piece can then be applied, and trimmed 'in-situ' to perfection, ensuring that it wraps around a little.
-Heat gun
-Solvent (metho) & rag
-Trimming knife
-Soapy water for application & another rag.
:huh:
Charles: Sorry mate, I'm not prepared to send my two passenger side doors to Victoria for you to do them :lol: Once jrm has this quote he can compare that to your price though ;)
You are quite wrong, I left my car outside for the last few days, since its Melbourne, the vinyl went through some crazy weather, heavy rain and 38c days and it is still spotless :down:
The only time it will collect dirt and grime is when someone runs their hand on my vinyl over and over and over and over lol, and even then, a bit of water and a wipe, it's clean again.
I'd like to see how it looks with a clear coat. If it's nice and dark/glossy then I'll get you to attack my MR2's interior for me :P
I'm thinking of doing a custom thing to go over my auto box (the bit where it says P, R, N, D, 2, 1) coz it's become faded. Would that be hard?
Edited by jezza boii
I'd like to see how it looks with a clear coat. If it's nice and dark/glossy then I'll get you to attack my MR2's interior for me :thumbsup:
PM sent :P
Im liking it quite alot.. except the sides of the wing.. a little too bland for me..
I really need to get some for my B pillars
For B-pillars, if you want, you can send your pillars to me and I'll wrap them for you for $40 (20 each)+postage back to you :D
Or I can send you 2 pieces of CF vinyl, enough to wrap both pillars for $40 ;)
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
