Hey charles got all my parts yesterday evening but didnt have a chance to get em back in but will definatley post some pics for everyone to see, the looks awesome! cant even tell that its been wrapped!
  • Replies 477
Awesome! Glad you like it :D
That rear bar looks good man! My only issue would be being so close to the exhaust? It gets pretty fkn hot in that area when driven in anger!
So far so good, been driving in the 36degree heat :)
I think the vinyl will be fine there, as it can stand up to 200degree heat from my heat gun :cool:
But I'll keep you guys posted regarding the exhaust heat.
I'm tackling some R33 mirrors at the moment and will post up pics when finished :P
nice work you have inspired me to try wrapping some stuff on my car now i love diy :D
got any tips for other wrappers?
just bought some and looking to do the end caps of my gtr wing and mayb the wing blade down the track i see how i go!
is the heat gun necessary or would a hair dryer be sufficient?
nice work you have inspired me to try wrapping some stuff on my car now i love diy :)
Hehe thanks :)
As for tips.... Just be very patient with it because if you don't get it right the first time, you can always peel it off and try again. Also try not to stretch it too much, or else under when heated, it will shrink back to original size.
You can use heat gun or hair dryer, both does the same job. I started off using a hair dryer, but it only had 3 speeds and 3 heat settings, so I moved onto a Bosch heat with LCD display of the temp. Which I thought was much better, as I know how hot to have it for certain curves :)
lastly, remember to not over heat it, I think maximum is 250 degrees, after that, the pattern will just melt on the vinyl and become like matte black lol.
have you seen the neffy wrap vinyl? i heard its better
website is http://neffywrap.com.au or the oz distributor
http://xposed.com.au/australian-distributo...effy-wraps.html
theres pics on ozhonda for it, he actually compared the 3m vs the neffy previously as the neffy product isnt self adhesive so applying it is very easy
sample photos he has
Edited by ForevaZero
Yup, of course I've heard of it.
In fact... IMO, neffy is not better.
Yes, neffy is like 1/3 of the cost of the 3m vinyl.
BUT, neffy does not have adhesive backing, therefore, additional adhesive is required, that means, when applying, to repeel and re-use the same bit of material will become a problem. Not only that, after being applied, if you want to peel it off, that might become a problem as adhesive was used to secure it. Where as with the 3m vinyl, it's got self adhesive backing, you can peel off and re-use it as many times as you like (well pretty much), if it gets all creased, use a heat gun and boom! it returns to how it was before you even started. Or if it starts to lose the stickiness due to dust or oil, you can just wash it off with soapy water and it will stick again. Also the 3m self adhesive is easily reversible, just heat it up a little bit with a heat gun and off it peels.
Apart from that, the 3m vinyl has a gurranteed 4 years lifespan outdoor with UV protection and 12 years indoor, while the neffy does not offer UV protection and its not recommended for outdoor usage. And as much as you say you use it for interior (indoor), there will always be sun (UV) shinning in from your windows.
God damn it, when are we gonna see some r33 interior shots with this stuff?
Oh, that reminds me to upload some pics of the R33 interior that I did last week haha!
Give me a few mins :D
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
