Hey, i have a R32 with rb25 na. Seems to be sluggish in low revs, anything above 4000rpm and its good, what can i do can a different tune or anyone else experienced this and found a solution??
cheers
Welcome to Club N/A where no power off the line is just the beginning.
Do u have an aftermarket exhaust? if so, it may be too big and actually cause a lack of back pressure resulting in the car being extra sluggish in low revs until a higher velocity of exhaust gas flows out, where it would be better for it...
oOoO rb20...even worst lol
shoulda atleast tried to get a rb25.
but yeah 2.5inches is max you should go on a n/a otherwise you'll end up loosing back pressure.
2.25-2.5 is optimal for best performance. with a decent muffler and have it made as straight as possible.
is 2.5 inch exhaust system good for a na rb20de r32 gts?
on your car, i personally would of gone 2.25 as i think 2.5 is too big.
hahahhaah lol
no need to laugh at him man, he was just after some advice.
you could always give the CAS a good twist in the advanced direction. will make it pick up much quicker, but the engine won't last that long.
Premium fuel goes a long way, I've been running mine at full advance for years, not a problem. Even in the peak of summer, full load, doesn't even think about pinging.
Definitely give that CAS a little twist, free HP imo.
if you are able to run full advance without pinging (unless you are running c16) then i wouldn't be suprised if your timing belt is 1 tooth out. or you just don't know what pinging sounds like. but then again the ecu is probably knocking 15 degrees of timing out because it is hearing the knock, so you could probably back your timing off a bit and not lose any power.
wtf i have a rb25 in mine, i have full exhaust system 2.5" with hi flow cat. worked diff and gearbox. adjustable fuel reg and gay ass pod filter. was thinking about extractors and chip it and give it a more aggresive tune
Run a few tanks of 98 fuel.
Remove any excess weight (stuff in the boot) - I'm guilty of having too much stuff there :rolleyes:
Check your tire pressures.
Clean your throttle body - you will be surprised how dirty it gets.
Try putting the pod in an enclosure or go back to a stock airbox and panel filter. You could be getting too much heat on the intake side of things.
Also are you running fairly wide tires and/or air-con? This causes alot of drag (resistance).
"Premium fuel goes a long way, I've been running mine at full advance for years, not a problem. Even in the peak of summer, full load, doesn't even think about pinging.
Definitely give that CAS a little twist, free HP imo."
how do you do that?
Edited by R34 -_-
the CAS is located on the front of the engine. it is a round thing with i think 3 bolts located at even intervals around the outside. each bolt will be in an ovalised slot allowing movement of the CAS.
this should only be done with a timing light and having locked the ecu into timing mode first. this way you can monitor how much you have altered the timing. if you go too far and get pinging/detonation/knock and don't realise it, it can result in engine damage. also make a mark on where the timing was before you started so you know how much you have moved it if you want to back it off a bit.
The belt hasn't been changed so it's not a tooth out and my brothers r33 gts had his on full advance aswell for years (when it was na). I know what det sounds like, she ain't pinging. Also when the stock ecu hears det and takes out 15 degrees of timing all of a sudden its noticeable, which it definitely isnt doing.
Not suggesting every just go and smash timing as much timing into theirs as possible, but for mine and my brothers, full advance worked a treat.
You cant hear an engine pinging, unless its pinging REALLY bad. Every engine is different. If you were to play with the timing, then you really need it up on a dyno to make sure its not pinging at all.
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
