I currently have a 1998 R33 GT-R V-Spec (Series III) with some minor modifications...
- Haltech Platinum Pro ECU
- HKS Priest Exhaust
- Trust 105mm Front Mount Intercooler
- Greddy Profec B Spec II Boost Controller
- Slotted Rotors/Project Mu Brakepads
- Other minor things
This was good for 222awkw (rwkw would be slightly more but I didn't dyno that). I have only owned the car for 3 months and I personally had the ECU fitted along with the dyno tune and some other bits.
However, the usual story... I have quickly grown used to the power. More power needed! :P
I have been doing some research and I feel that I should be able to reach 320awkw with stock internals. These are the proposed mods...
- HKS 2530 turbos
- Tomei Pon Cams and Adjustable Cam Gears
- Tomei Fuel Pump
- Nismo 600cc Injectors
- Nismo GTR AFM's
- HKS Stainless Dump Pipes
A couple things of concern are the injectors and the AFM's. I initially planned to go with 700cc injectors to allow for future upgrades but I was advised to go with 600cc due to my power goals and the fact that they are a straight fit. What do you guys think? What sort of power are 600cc injectors good for (in case I want to add more later)? Should I just go for the 700cc straight up?
In regards to the AFM's, I was informed that the Nismo GTR AFM's offer better airflow (and a direct fit) than the Z32 version. Is this the best way to go?
Any other comments or advice on the above, please feel free to do so.
Edited by Shinrai
  • Replies 64
If the R33 afm's are the same as R34 units, you dont need to buy any other air flow meters. My R34 was tuned with the stock units and it's made almost 330awkw.
Cams are also not necessary as well to make that power.
6 or 700cc are fine, I think I would use 700s, just in case if you want to go more power later. Im using 800s atm, bit of an overkill as the duty is only on 55% but I plan to go over 400kw in the future.
:thumbsup:
You can tune beyond their "range" but I would not risk doing it. I would go the Nismo AFM's if I had to, but I went with MAP sensor.
Edited by bigmikespec
for a strong 300awkw i would keep stock cams, adjustable cam gears to adjust the power curve etc, nismo AFM's and tomei/nismo in tank fuel pump like you stated, 700 or so cc injectors (herd its better to go the biggest you can to allow for future power increases) and 2530's would be perfect and wont be laggy like running twin GTRS turbos etc
What do you mean by MAP sensor? This means that the ECU measures air flow, right?
I think my ECU has that feature also, it is a Haltech Platinum Pro and the specifications state... "Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost". Does this mean I can use my ECU instead? Which is the better way to go?
hmmm i think you dont have to run afms with that ecu, its like the power fc d-jetro wich uses map sensors instead....best to look on there website and find out for sure
if u dnt hav to run afms, dont. some say their a restriction on the inlet path (they got mesh inside)....twin steel airtake pipes with filters clamped on the ends would be the best way :)
Edited by SiR_RB
If you're not aware, they can go further than 330kw actually, so why waste money on something that's not really necessary.
map sensor measures "manifold air pressure" not the airflow :). it would probably be more expensive to swap to a map sensor than to get new afm's
You didn't get the work done at PowerTune by any chance did you? I have just been talking with them as they did the previous work on my car and I am very happy with the service.
Anyway, they said they just tuned a R34 with an Apexi PowerFC, 800cc injectors, Pon Cams, Adjustable Cam Gears and a set of Garret 2560-5's. Apparently it made 328awkw (20psi boost), which is the figure you mentioned with some of the parts you also just mentioned.
Edited by Shinrai
Yes, they have been good to me also.
By they way, it wasn't them that recommended the 600cc injectors. That was somebody I was looking at sourcing my parts through.
Back to the AFM meter thing, PJ from PowerTune did mention your tune to me as a reference and he also said that if I wanted to achieve a higher power figure that the AFM would hold it back with the other mods I am considering. I think that the R34 units might be different to the R33 too.
When the bug bite's it bite's hard! It would be turbos only for me!, next upgrades, fuel pump, injectors, cams, cam gears, AFM, dumps, clutch, catch can, gearbox, suspension etc = $$$$ + possible shit heap on the road, I would keep it simple for now, enjoy and maybe wait till you do an engine.
You mention that you've already got the haltech ecu ya? If thats the case, maybe check if you're actually running AFM now. The models seems to be able to run on map sensors but maybe the map sensors are additional items which users have to purchase seperately (like de-jetro, ecu itself is around 1k and if you include sensors looms etc the real cost of the package is around 1.7k).
In any case, tuning a car without afm takes longer according to a couple of tuners. It can be done but if you're not after huge power (imo anything above 500awhp is huge), I personally wouldnt recommend map. Like what Eugene said, why pay for something extra which you dont need?
Once they run out of resolution that is it, the tuner is guessing, how good is the tuner? Not good enough for me (personally) wanting to risk it.
You are saving money if you buy (or already have) an ECU that is capable of using a MAP sensor instead of AFM's. Instead of getting a new ECU and AFM's as well...? Which is wasting money that is not really necessary!
Mike
edit: between MAP and AFM's there is f**k all difference between drivability too.
Of course. If you're already running map, there's no point in going getting another ecu just for AFM. I'm just saying if you dont have anything for starters. Reason being time spent on tuning when the same outcome.
Not buying an ecu its a saving on its own.
Yes, I do have a Haltech Platinum Pro which has a MAP sensor.
I apologise for not putting two and two together earlier. I thought I still needed an AFM until talking a bit more with you guys here. So, the good news is that the AFM debate is null and void in my case... Yay!
I am waiting to get a quote back from the workshop and then I have to convince my Wife to put all that money aside for my baby (I think some jewellery, clothes and shoes etc. may be needed to get her on side :) ).
Awesome... Thanks. I was beginning to think that it might need to wait a while as it has all added up to more than I wanted to spend at this stage.
I might just look at the turbo's and the neccessary mods at this stage. :)
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
