no race km, engine not tested. I purchased engine after it was taken out of car.
Just checked with my machanic who found me this engine, it wasn't out of a half cut like I thought. It was from a going R32 GTS-t. Engine purchased from another workshop who was doing some high performance stuff to the owners car and onsold this engine after it was removed. Was ensured it was a fine engine.
https://www.sau.com.au/forums/topic/296735-fs-rb20det/#findComment-4943248
i was gonna ask about compression of cyl and also if there are any known oil leaks or issues with engine.
https://www.sau.com.au/forums/topic/296735-fs-rb20det/#findComment-4943417
engine has no oil leaks, I was going to strip it and race prepare it, but I am also confident speaking with the people who I purchased it from, it's a sound engine. If I had been able to compression test the engine I probably would have listed it for $1000
https://www.sau.com.au/forums/topic/296735-fs-rb20det/#findComment-4943555
:action-smiley-069: so your selling it for $690 and assuring us that its spot on and you trust your mechanic but if you were to compression test it you would want $310 more :happy:
Not trying to cause trouble just find that interesting and amusing at the same time!!!
https://www.sau.com.au/forums/topic/296735-fs-rb20det/#findComment-4945566
:D so your selling it for $690 and assuring us that its spot on and you trust your mechanic but if you were to compression test it you would want $310 more :P
So you pay more for an engine that you couldn't compression test?? Thanks for your coment Ben, but next time think before you post!
https://www.sau.com.au/forums/topic/296735-fs-rb20det/#findComment-4946932
Not at all, what i find amusing is that your stating the engine as being in excellent condition out of a running car but you dont know the compression of the engine, it hasn't had a leak down test. You said if it had been compression tested then you would ask more and that is the part i find amusing as personally dont think it helps your sale!!!
If the engine is as good as your claiming then why not ask more straight up seeing as they are harder to come by in good working order???
Oh and for the record id never buy an engine that i couldn't compression test :D
https://www.sau.com.au/forums/topic/296735-fs-rb20det/#findComment-4947058
Oh and for the record id never buy an engine that i couldn't compression test :)
Ben, have you read all posts? I have never stated the engine is in excellent condition. I believe it a sound engine given the information from people I know and trust. So having siad that, this engine is obveiously being sold in as is condition. I could have lied to other members and said it has been tested and it's fine. So given all the facts Ben, I don't believe I could expect anyone to pay more. Does that sound logical to you?
If your not interested in buying this engine than please don't bother replying
https://www.sau.com.au/forums/topic/296735-fs-rb20det/#findComment-4947322
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
