R34 Gtt For Sale
Righto, as seen on subject title, r34 gtt for sale with a few decent mods, this car has not been brothelised
Bored out to 2.6L with forged pistons, rings and rods.
Metal gaskets,
heavy duty valve springs,
excide cushion button clutch,
Nismo full adjustable suspension
17inch buddy club p1 racing rims,
3"turbo back blitz exhaust,
apexi power fc ecu,
dual stage boost controller,
plump back blow off valve (GFB)
Splitfire direct ignition coild packs
Apexi Pod filter inclosed in cold air intake box
Large front mount intercooler
Pioneer Head unit with 6"momo pulk splits in the front an 6"momo pulk in the rear
the car has 92000 on the clock but motor only has rougly 30,000 on it since bore, valve springs, clutch an new pistons
most of the work was done by RECUSTOMS
Awsome car to drive unless your names Ray Evans who hates these clutches, serviced every 5000 with motul 8100.
selling the car with standard plates for $24,000 ono
send me an email [email protected] if ur interested
cheers
Edited by Anth34
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 10 months later...
 Share
    • That is typical (for a rb at least) with a medium to large turbo, noting the format of the graph is probably misleading what you see a little (half portrait width but full height, in landscape it would look quite different) Basically until it hits target boost the torque curve is rising steeply, when that is 4000+ rpm it is not great to drive since almost all of your life is between 1,000 and 3,000 rpm. Once you hit target boost the wastegate opens and torque stops rising so quickly. From there the shape of the curve depends mostly on the cams and where they have a peak vs the rev limiter
    • Last of the maintenance items for now....not sure why but the drivers side window switch had heaps of wear on the right front and right rear switches Unfortunately, unlike earlier Skylines the controls are bolted to the door trim from the inside. So....off the with door trim. There are bolts or screws: Behind the door handle cover, pop it off from the handle side Under the rubber trim at the bottom of the door pull (also just pops up) Behind the courtesy light at the bottom. Other than that, just window down then pop off the usual selection of push in clips around the perimeter and the trim lifts up Interesting that they have a bolt on cover instead of the old school plastic held on by goop....I guess they prioritised sound levels over price Then, 2 screws and 2 plugs to replace the switch (looks identical to the Fuga/Q70 one incidentally) and put it all back together. Also much better
    • ok I understand, but the majority of turbo vehicles lose torque, or have a flat torque curve after the spool.  hence my initial misunderstanding. I didn't think this type of curve was possible
    • It is completely normal. Your original understanding is what was wrong, not what you see in the charts.
    • made with turbo and tuned by (hypergear)
