  • Replies 136
It's gonna be a good night :blink:
It shouldn't need to be said - but for the record to anyone who is planning to come down... all are welcome, but use common sense and do not behave stupidly.. anyone seen to drop a burnout or driving dangerously will be filmed and video with plates provided to police. There will be a lot of people walking around, and parked cars on both sides of the court so just drive safely.
Looks like it's going to be fun to get my POS out of there on this friday after its been there 2 months, might have to ask ray to park it 2km from the place so it's very far out of sight :)
My car leaks a bit of oil (under pressure only), is it ok for it to go on Ray's dyno? I don't have time to fix it yet........
Yeah that's fine... there's been more than one car dripping oil on the dyno before.... rotaries and all
Guest
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
