hey guys
mate of mine hit a curb and bent my lower control arm... I pulled it off and replaced it but the camber is still out cpl of degrees. The people at the tyre shop said some car have adjustable camber or have alittle bit of play in them to adjust them. Do R33's have this. Its for the rear wheels
Cheers
Hey mate
The same problem happened to me and I have already had to replace 1 set of tyres and now I can see it coming back again (the inside of the rear tyres wearing out). I took it to the tyre shop and they did a wheel alignment and adjusted it slightly but the standard suspension is limited on how much you can adjust things.
Whiteline state that the recommended camber for the rears is between -1 to -1.5 degrees i think? What do other people think?
So maybe take it to a tyre shop (if you havent already) and get them to do a wheel alignment and see how far back they can adjust the camber. Otherwise something else could be bent..... or you might need to look at a adjustable camber kit.
I'm no where near a expert but thats my two cents worth :)
