Hey all, some of you might know me from this site, some might not. Either way, I've had my skyline for 9 months or so, and my journey has been interesting. I've learnt a LOT along the way, about RB's, and about cars in general. I thought I'd share my story of dealing with Tuff Toys.
So around December 08 - Jan 09 I started looking for a car. I had a falcon at the time and wanted something japanese and turbo! Test drove a couple of 180s and silvia's, drooled over an S15 or two but they were plain out of my price range. A couple of months before this, my workmate and I noticed Tuff Toys moved into Virginia, next to All Jap... we both drove past it each day on the way to work and always talked about how much we both wanted a sick car from there... hahaha.
Went in and spoke to them, told them what I was after and they were happy to help me out, let me test drive one of their 180s I had my eye on, and were always happy to have a chat and answer any questions I had - and I had a lot hahahaha.
Their cars were a bit out of my price range, fair enough.
I ended up finding my 33 at another car yard at Motorscene at Albion, simply because it was cheap. Had a friend look it over and I was sold.
Over the next couple of months I took my car to Tuff Toys to replace/upgrade a few basic things:
  • Oil, fluids, and filter change straight away
  • I had them take out the coilovers that were in there and replace with stock shocks and kings low springs
  • Brake pads/rotors
  • All 3 of my 3 month/5000km services so far (could do them myself but I need it done by a shop for my warranty)
They've also helped me out with figuring out weird noises (boost leak from BOV gasket) and helped me reconnect my turbo timer when its wires came loose in the dash because I was fiddling in there (!). They taught me about my manual boost controller and told me how to connect it/reconnect it (I wanted to DIY it to learn how it worked at the time), as well as helped me out with a multitude of noobish questions from me and have always been more than happy to help me out without charging for stuff like that.
They've never stuffed me around, and I've never been surprised at the cost. If anything 'bigger' had to be done, they've let me know and told me how serious it is and how long until I'd need to do it - which is EXACTLY what I want in a mechanic. If you need anything mechanical done, I'd have no problem recommending them to the skyline community. Wayne knows his skylines and has realistic expectations from them.
Anyway, my two cents. Cheers.
Edited by mosquitocoils
https://www.sau.com.au/forums/topic/296802-tuff-toys-importersmechanic/
Hahahahaha yeah.... to be honest I HATED the coilovers. Waaaayy too stiff for street use which is all it will see while in my possession, other than the odd drag soon.
  • 8 months later...
Somehow they got me on their mailing list and used to email me every week with new cars they had.
I haven't heard from them in about a year or so and there's no website for them.
I'm not sure what's next to justjap now though?
Hey guys PM me if you want the mobile number for them... they've moved out of Just Japs property and moving over to the southside from memory
Tufftoys arranged compliance for my Skyline personal import from japan and were very helpful , I cant compalin about anything.
Moved to
Shed 2 / 298 New Cleveland Road
Tingalpa Qld 4173
Phone: (07) 3390-4277
    • I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
