  • Replies 52
Nissan is a good start
Either way unless you're changing the belts yourself, sometimes its better to just let your mechanic buy the belts for you (assuming he is an honest bloke!). They get trade discounts, and if they buy the wrong ones it is their own problem.
I am due for some myself..same prob with the cracks...the Burson sales person told me to take mine off, then take it to the Burson store and he'll find me the 'right' replacement ones...when i get them done, i'll post up an aftermarket part brand/number...
best of go nissan , as most time aftermarket will be shorter or longer anywhere from 5-15mm depending on belts and then you will have problems with instaling the belts
nissan will have right belts for our cars and no stuffing around , they will fit 100%
I saw the smaller of the two Gates Performance belts at supercheap for $24. I'm going to do some ringing around to see if anyone caries a larger selection.
Wow thats exceptional value considering the prices from nissan (for 350z oem). Will check out super cheap also and see what I can find. Thanks for the info.
Make sure you're checking out the Australian Gates Online Catalogue.
Go to www.gatesaustralia.com.au then click on Auto Aftermarket and finally On Line CATALOGUE - Automotive.
You might have to log in (just some basic details etc) the first time but once you're in I think you can add the webpage as a favourite and not have to worry about logging in from then on.
With automotive micro-V belts the part numbering is pretty simple. 4PK915 = 4 ribs, PK pitch (classifies the cross section and distance between ribs), 915 is the length in mm. On cars like mine, R33, they have threaded adjusters and not hydraulic tensioners you have some room to play with so don't need to be 100% on with the length. Just note some belts could have K040360 or similar on it which is the same belt as a 4PK915 just in imperial, so 36.0 inches long. There should be a length that matches the V series skylines.
Edited by Fry_33
There is no listing for an Australian part for the V35/350Z, hence the offshore link. Best call them and double check but failing that you'll have to order it from the US if you want the gates racing accesories belts
Edited by mosoto
Oh, sorry, I didn't actually check it. I'll have someone look into getting it updated tomorrow if I remember. I figure it will be the same as the 350Z so it is something that should be in there. I wonder if it's similar to any other models like a Maxima? Gates might already stock it here but it's just not linked to the V35 as an application which happens occasionally.
I just checked the Gates Australia Online Catalogue and they list the following belts for a 350Z.
Z33 (2002-08) - 3.5L V6 24v DOHC EFI (VQ35DE) - AC
Belt = 4PK945
Z33 (2002-08) - 3.5L V6 24v DOHC EFI (VQ35DE) - ALT
Belt = 6PK1170
Those part# are for standard belts yeah?
Interesting, no listing here for the micro V Performance belts: http://www.gates.com/australia/downloads/d...folder=brochure
If anyone is after performance belts : http://www.powerenterpriseusa.net/products...timing_belt.htm
you'll note the Z33 shares the same AC belt as the BNR34 as well as others.
Edited by mosoto
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
