  • 2 months later...
  • Replies 52
To keep it simple, if you need your belts changed, and you are in Melb:
1. Call Chris at City Nissan and ask for the belts to be changed 03 8383 8822
I did my belts today and got spare change from $200....I was shocked by how 'cheap' the job was...I was think more like $280 or something...
Why go for aftermarket when you can go for OEM? I feel so much easier now, after having replaced the belts...
Hi All,
I have the 300GT and my belts + labour was $160 + GST from the local Ultra tune. Not sure if its different for the 350GT.
Had to get it done because a bolt from the engine block had somehow worked its way free and started eating through the main belt. It had 2 teeth remaining when I noticed, would have thrown it a couple of days later..
Cheers
Lee
Hi All,
According to FAST and Parts Master, the two belts (AY140-61175 and AY14N-4094E) are used on the following engines;
VQ25dd
VQ25det
VQ30dd
VQ30det
VQ35de
  • 1 year later...
hey guys didnt want to start a new thread, but i need some belts again, this time for a 2004 (series 2) v35 sedan 250gt - the part number is mentioned but no one has mentioned the actual size for the 250gt sedan, any help?
  • 4 years later...
Sorry to dig up a old thread. Today i purchased belts that have a completely different part number from Gates via Repco. They are the Micro-V.
4PK775 6PK1080. They suit Nissan Maxima 3.5 VQ35DE. My car is a late 2005 coupe. I can't see why they will not fit. Its the same engine or am i missing something?????
yeah, just because they are the same engine, doesn't mean all the accessories (alternator/power steering pump, aircon compressor, tensioners), are all in the same positions, these items get moved around to suit the engine layout, and therefore use different sized belts.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
