Hey guys,
I've been doing some reading on EPAs/ Canaries the past couple weeks, and just wanting to get a solid yes or no and explanation if possible to this question...
For a Police Officer to issue you an EPA or defect, does he/she require a TMU license?
This has been discussed in another thread somewhere but I couldn't really grasp a definite answer to my question from reading them :)
Cheers guys
https://www.sau.com.au/forums/topic/296835-some-clarification-please/
on top of that, I read somewhere that even ambulance or fire fighter officer can report your car and EPA will send you a notice straight away.
or if you get spotted by EPA officers themselves - my old R33 got reported that way. drove side by side with a white car with EPA logo on the door in the traffic jam.
the only exception is if it's general public member, then EPA / police will have to do some kind of an investigation or wait until similar reports happened that matches the description of your car before taking action.
I have heard that cops, ambo's a firies can report you and you get an epa notice, if the general public report you they need 3 complaints before they send you an epa.
I wonder what's to stop the same person sending 3 complaints under different names if they've got something against you (ie my neighbour)
Nothing, same as the littering hotline, once they dob you in its then your task to prove that it wasnt you.
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
