ok guys
im going to try the rb26 intake plenum on rb20 conversion
not going with the itbs tho im staying with the single throttle
my plan is to weld the rb26 plenum to the rb20 cut runners and the throttle to the plenum opening
as seen in the pic below
i just need to know this
there are many lines and stuff connected to the rb20 manifold must look like vacuum lines
will there be places where i could connect those lines on the rb26 manifold?
also there is a device in the back of the stock rb20 manifold im not sure what it is for tho, it looks like it has sum to do with the idle
what do i do with that ?
plz help
if you happen to have any links with these conversions plz post then
thanks
https://www.sau.com.au/forums/topic/296895-rb26-intake-plenum-onto-an-rb20det/
For the AAC valve I had a boss machined up and welded onto the bottom of the plenum.
There are also plenty of vacuum connections on the 26 plenum.
I'm using a Q45 throttlebody and still have the engine fan (unlike that photo) and using GTR plumbing, I've had to push the throttlebody as far back as practically possible (these things are huge!) and will probably have to weld a bend straight onto the throttlebody.
What they've done above with the water outlet is interesting but my throttlebody is in the way :action-smiley-069:
Just be aware that the RB20 runners don't line up with the runners on the 26 plenum.. we had to heat and bend the first and last runners in and find a happy medium, the GTR runners are smaller and the 20 runners have much thicker walls so it wasn't too bad but it looks damn ugly on the bottom lol
Edited by bubba
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
