Hey guys im currently building an RB26 with an rb30 bottom.
the motor is out of a 32.
first things first. bottom end,
is there any difference in the standard rb30 block and the turbo block?
Can i use a crankshaft out of rb25/26 or does it have to be a rb30 one? anyone know how much hp a standard vlt crank can take?
going to put forged pistons and conrods (probably CP pistons and spool rods anyone used these before and how much hp can they take?)
The waterpump and oilpump are close to new so useing them shouldn't be a problem or is it better to replace them?
i was also told that i should put a reducer in the oil line as top end will suck heaps of oil and starve the bottom end.
thats about where my knowledge ends, i'm sure theres a heap more things that a required to do so im after some suggestions
For the top end was gonna put a big set of cams and a 1000roller of some sort... obviously goona need a computer to piss off the AFM and shit so which computer would use recomend i use.
If anyone has done this build before and has a list of stuff that had to be done/modified that would be helpfull.
https://www.sau.com.au/forums/topic/296925-rb26rb30/
Guest
