Door Pack is sh*t..really!
Buy the Bulk pack.I did..glad I did.
I think it's actually called the Trunk Pack or something like that.
But yeh, bout half the pack on each side should get the doors nice and stiff to absorb the bass and will give you clean notes.
I don even need a Sub anymore. Got 6x9's in the back aswell!
https://www.sau.com.au/forums/topic/296928-dynamats/#findComment-4946199
the skyline doors really sound sooooo much better with lots of sound deadener. like a new car when you close it.
my GTT has innner, outter, and sound mats behind the speakers. and the door panels now have foam filled handles and other sound deadener to stop the squeak between the lower and upper parts when your hip leans on them... annoying !!! plus my door pockets are going to be gone this week and filled up with another pair of splits...
the little packs that dynomat give you isnt nearly enough to do a small door properly, as chris suggested above.
there are a multitude of products that do the job, some better some worse..some you find at Bunnings for next to nothing hint hint
and for all those people who think its too heavy for a street car,clean out your macca's wrappers.... I'd rather my car sound solid built then a rattle can . you can only drive so fast on the roads anyhow? if I wanted a race car I wouldnt put a radio in it...end rant ...lol
https://www.sau.com.au/forums/topic/296928-dynamats/#findComment-4946942
personal preference my friend. i usually put some on the inner skin, then line behind the speaker with plain chant, then seal the door up totally, then put a sheet of dynaliner across the whole exoskeleton of the door. www.dynamat.com has some good tutorials on it.
https://www.sau.com.au/forums/topic/296928-dynamats/#findComment-4949215
dont overlook some of these videos
http://www.secondskinaudio.com/installation-instructions.php
Dynomat isnt the only company who does this
Stinger is another good one
my car doors are damn near sealed , my two sets of split speakers dont even fire into the door chamber they have separate chambers sealed with carbon fibre and fiber glass molds and custom horns for the tweeters molding into the door panel shell. the sound deadener is for the rattles and to keep the SPL inside the car
(photos will be posted up on Audiocontrols website soon for all to see the build up)
https://www.sau.com.au/forums/topic/296928-dynamats/#findComment-4950799
keen to see some horns in a car! don't see too many horns being used in australian car audio.
all to be revealed very soon...lol
Sponsors website when revealed
http://www.sound-better.net/gallery/Show-Offs/Show-Offs.html
https://www.sau.com.au/forums/topic/296928-dynamats/#findComment-4956927
they do seem 2 be more populay in the US than Aus, proably cause they are more dificult to install
I've never installed them bet have listened to a few that just sound majic. ( & some that sound poo)
as always the more effert put in the greater the reward
Horn in the door ..... NEVER seen that.. wish I lived in hoonsville 2 have a listen
Edited by BundyBear
https://www.sau.com.au/forums/topic/296928-dynamats/#findComment-4973299
Horns cost a fortune for "image Dynamics" or similar, and take a proper designed system to make them sound good, plus a lot more space to mount
there not store brand horns,,,, there very custom hand made ones and yes designed properly up too the point I could , using the space and car audio speakers instead of Pro Audio sound gear for concerts...lol
once the system is tuned I can post the RTA curve if anyone wants or ?
https://www.sau.com.au/forums/topic/296928-dynamats/#findComment-4974374
yea 4got bout the $$$, seem to remember reading a Mag article years ago( b4 the intaweb thingy) about a system with hand made horns (posibley one or the Ausie car audio mags)
damd things always fasin8td me but could never convince anyone 2 let me try'm in their car ( can't blame em really)
P.S. ya probably guest but yep im an X Backyarder, by X I mean I only do MY cars these days ( I like 2 play by my one rules sometimes)
cheers
https://www.sau.com.au/forums/topic/296928-dynamats/#findComment-4975034
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
