just picked my car from the mechanic and he tells me that i have a cracked piston and rings, the car has been playing up for a little while. I was pretty sure it was on it's way out. now I know.
the question now is do i rebuild it (what cost are rebuilds worth), or get a second hand motor.
i am not trying to get the most powerful car out just want a car the has a bit of go there when i want it, Any advice would be great on this.
https://www.sau.com.au/forums/topic/296933-dead-motor/
are you going to sell the car or keep it?
https://www.sau.com.au/forums/topic/296933-dead-motor/#findComment-4945631
just a stock rebuild then.
1k motor in/out, then 2k for the rest. New pistons all round, bearings, whatever machining might be required, gaskets etc etc.
+1
You also didnt mention what injectors or ecu you are using, if they are standard upgrade both and with a tune you might see closer to 250 depending on the turbo you have.
Im not up with how strong the auto's are but at that level you also be pushing the limit of the standard auto i assume.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/296933-dead-motor/#findComment-4946248
Pushing that much power with an auto I would be looking at picking up a shift kit and after market converter... My stock gearbox lasted a couple of days even with a shift kit running 240rwkw. I put another standard box in thinking the previous one may have been a bit tired, and this one died a day later also lol. Killed drive and reverse which apparently work off the same clutches.
If you are keen on getting this gear, let me know. I pretty much have a brand new converter (3000rpm) and shift kit I would let you have rediculously cheap just to get it out of my house haha. If not keen on second hand gear, speak to Mike at MV automatics.
https://www.sau.com.au/forums/topic/296933-dead-motor/#findComment-4946581
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
