Hi guys,
I purchased some rims from interstate and i received them today.
The courier obviously damaged them abit and scratched a few..
but i dont mind i might just get them powdercoated soon
I need some help with photoshoping..
can someone please photoshop my new rims on a pic of my car when i purchased it!!
cuz i havent had a chance to take a side profile of the car!!
does anyone know of anyone who does a great powdercoating job??
Also can someone photshop them in black to see who they will look like??
Does anyone have 215/35/18 tyres around that they wouldnt mind selling??
Let me know guyss
thxx 2 who does the photoshoping :)
Thankyou guys
https://www.sau.com.au/forums/topic/296964-new-18-inch-rims-need-help/
215 is perfect for those rims as there only a 7.5 or 8 wide
215/40R18 or even 225/40R18
235 will be too big on them and bulge out over the rim alot
215 would give best look, 225 would bulge a little bit but not really noticable
yeah but a 225 is uncommon and will run you a bit , possibly same with a 215?
nope very good price wise, there are a few good brands out now that are cheap but really good quality wise, plus 225 are starting to become more popular due to euro cars, and lots of ricers run 215 to clear guards
yes 235 is a very common size, but you can still pay big dollars for any tyre, it depends what you want it for...
id photoshop them but the pictures are taken at the wrong angle. The third pic is close, but compare the angle of the rims in your first pic, compared to the other pics, wont sit right!
Also Marshall Powdercoaters do good work.
oh they are only narrow pizza cutters. *faceplam*. this is why 33's get such a bad rep.
first of all i would never go a 215/35 on ANYTHING. the speedo will be thrown out by 5km/h at 60km/h. thats reducing the overall rolling diameter by too much. a 215/45 is much better and retains a pretty much stock rolling diameter. i would only go a 235/40 if the rims were at least 8.5" wide. anything narrower and u will be riding ballon spec.
btw thats a hell dodgy spray job, couldnt the guy at least tape off the tyres.
honestly i wouldnt spend money on powder coating these. put that money towards better rims.
Edited by steveP
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
