Hey all,
Im throwing the interest out for a sale or swap of my ae86.
Engine: 2004 3sge beams from an Altezza
6Speed gear box and brand new tailshaft.
Suspension:
AJPS coilovers up front with 8kg springs
200m 6kg springs and short shocks in the rear.
27mm selby sway bar adjustable up front
20mm selby sway bar adjustable down back.
RCAS and power steering arms
Cusco camber tops.
Wheels: has some 16's on at the moment, but will come with more wheels then you can poke a stick at.
The car has recently had the beams motor installed and made 126kw at the wheels, the car is set up for track but also have the stock suspension if you want a cruising car with a bit of power.
Car is not engineered as the conversion has just been done, once it is engineered the car will then need to go through an emmission test, the car has a brand new catalyc converter as well. Along with a 2inch system all the way through and two rear mufflers one for street and one for the track.
Price $11k or swaps (interested in a 180 or cefiro, four door drifting love) (no commodore or falcodores)opdrift1.jpg
Pm for any questions.
Dave
https://www.sau.com.au/forums/topic/297008-ae86-with-3sge-and-6-speed-swaps/
Bump,
I want a cefiro :)
Hi, Where are you located. I have got a collection of Nissans from 180sx to GTR34s looking for a good AE86 to add on the list
cheers
Alex
cheers
Alex
Hey Alex,
Located in Sydney, but can deliver for the right price or the right swap.
Hey Alex,
Hi, I have got a black 180sx with Recaro seat. exhaust and full Monkey Magic body work, big front mount cooler complied ready to go.
Also, a 98 Chaser brought in for next years drifting champianship. B N body work, TRust FMIC,exhaust, HKS GT pro turbo, Cusco coil/overs Defi , Enkei 17"etc.etc. not complied yet cos the B N body is very agrassive.
What do you think?
cheers
Alex 0439 818008
  • 3 months later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
