R32
ako299
 Share
got my r32 dynoed today at powertune...
rb20det
stock internals
stock injectors
stock turbo
fmic
3"exhaust/dump
pod
walbro 500hp fuel pump
stainless manifold (leakin badly needs replacment)
apexi safc controller
drift bov
run on 12psi.. made 172rwkw in 41 degree out side heat!!!
was happy
have rb25 turbo and gtr injectors on there way, will put on once get manifold fixed or replaced aftermarket plugs and coil packs and then retuned!!
At the wheels.
For reference on a very safe tune with an HKS2530, fuel pump, injectors, AFM etc on a relatively good condition RB20 at 14psi bleeding down to 12 I got 175kw-180kw on a 33c degree day. Pulled 195kw at 16psi with massive misfires due to coils.
Could be a freak engine but its hard to imagine getting that much power out of a standard turbo.
Edited by Kwyjibo
Mate - those figures are wrong.
Have a look @ the IT temp is -71 (IT stands for Intake Temp Sensor)
They have a broken temp sensor, how can you be in -71 degree's on a 24 degree day?
Your coolant would be frozen solid - like i said mate, they have botched your runs, there is no possible way to make 170rwkw from a factory RB20 Turbo on 12psi
I suggest you find another tuner, if they can't even maintain or setup their equipment correctly, goodness knows what the tuning is like.
it was on a 41 degree day?air temp inside the shop and dyno room with the fan going would of been lower...
im not sayn u are wrong but i have a friend with the almost the same mods and he gets his car tuned at a different place and it makes 166rwkw with stock turbo???? my boost controller is set to 14.4psi on hi boost but has bad boost drop to 12 thats y i said on 12psi??? i have been told they were a good tuner
If it was 41 degree's outside then that is even worse champ.
The dyno sheet AT:24 (Ambient Temp) says 24 degree's was the temp during your tune/runs etc etc.
Which is virtually 20 degree's off, not a good thing at all, quite signifigant in terms of accuracy. ;)
I say this because if they can't get simple weather corrections/sensors working, i would be dubious of other things like AFR's being correct (ie the sensor being poorly calibrated/broken like the other ones clearly are)
That then has follow on impacts to the tune and at worst - your motor.
they didnt put a thermometer on it so the intake temp wouldn be right.. i dunno then coz my mate also has one with 166rwkw and has drove mine and says goes better than his... pretty sure if u look at the otha 32s on here u will c some with more power with the stock turbo..
Mate you need to calibrate the dyno if you are ever going to hope to have meaningful results for everything from the power to the AFR's
Plenty of stock turbo results to be seen here:
http://www.skylinesaustralia.com/forums/Rb....html&st=20
Norm is 145-160 give/take for 12-14psi.
130-140rwkw for 10-11psi
Normal temps (22-26) - Let alone on a 40 degree day.
It seems you don't really understand fully how a dyno works...
I've told you that the dyno they are using is not correctly setup at all, and this could easily result in a a poor tune and/or your motor death or serious damage over time.
So wether you choose to take what i've said seriously, or just don't care about your car/motor, is totally upto you.
I've seen plenty of people dudded by poor work over the years and it has cost them plenty of money to get it fixed down the track.
as i said it must be possible as i looked in the link and only looked at a few and spotted one 170rwkw on 1 bar boost stock turbo???
1990 R32 75000Kms
RB20DET Stock Internals
Stock Turbo
FMIC
POD
3" TRust exhaust
EBC
BP Ultimate
170.2rwkw @ 1 Bar Boost
Agree with Ash. Wouldn't be pulling myself over those results. Obviously a dodgy maintained, high reading dyno to keep customers like you happy who don't understand the basics behind how dyno's work and calculate the data.
People comparing chassis dyno results are only kidding themselves. To many variables.
lol -71 degrees Intake temp. your fuel would be freezing in the inlet...
you need to understand the dyno software takes into account ambient temp (AT) and intake temp (IT) and corrects the power figure accordingly. withh figures like those who knows what kind of power figure correction it would be applying. but I can tell you now it's very, very unlikely that your 32 GTST is making 170rwkw @ 12.5psi. just as unlikely as it has -71C intake temp...
upsetting to see this mate, ive always heard good things about powertune
maybe you should take on the info richard and ash are saying and give them a call and ask some questions, and try to get some answers and hopefully a re-tune/refund/etc..
also, keep your eye out for an rb25 turbo, a nice bang for buck upgrade for the rb20 :P
...like i said mate, they have botched your runs, there is no possible way to make 170rwkw from a factory RB20 Turbo on 12psi
yeh i have rb25 turbo and gtr injectors on there way... maybe they f*kd up.. ive seen a few otha ones making like 180kw + with stock turbo so i dunno... yeh powertune is supossed to be great
i think they f**ked up man, ash knows his shit
call them
yeah I dunno about this bloke but I have seen an RB20 silvertop on an A31 unopened with an Impul ECU, East Bear front mount GT-R cooler kit, 3" zorst no cat or mufflers and a R34 turbo pull 170 rwkw, the car's track performance was able to speak for itself (ie was able to cane a stock R34 GT-T, and give my old 160rwkw VN SS a hiding lol; I admit there would be a weight advantage since this A31 weighs 1200kg lol)
 Share
    • Hi all,   I have been a member here for years and am back to owning an R35.  It's my car and thought members of the community might enjoy sharing my journey.  I am definitely here to join the conversation.  If sharing this content isn't appropriate or it belongs somewhere else, I am happy to have it deleted or moved...
    • Data looks rock solid? I'm assuming you jabbed the throttle twice OR once? the TPS voltage moves up and down twice, however you've mentioned you did it once.
    • Having not watched the videos, I'm unsure, but this may be better suited to the importing thread?
    • Update on this situation: (Forgot to put in my previous post that I bought another brand new pressure gauge and fuel shows the same 50psi) I've deleted all the aftermarket immobilizers and turbo timer shyt and placed all factory wiring back to normal. The problem is still the same and nothing changed, but atleast it's a bit more tidier under the steering wheel. I've also siphoned out all the old fuel and then poured new batch of BP98 fuel (about 15L) into the tank. Nothing changed. Still the same idle. I also changed out the MAP vac line with a new one and, still the same.  So 2 days ago, I thought fk it. I'll just change out the fuel rail and injectors with another set that I know worked well in my brother's R34 a while back. That other fuel rail has the exact same Xspurt 640cc as what I have right now. So I changed it out to that other fuel rail and injectors (new O-rings) and injector harness. Put everything back together, started the engine, 464906286_1624569924763105_5179888796065901094_n.mp4   and yeah... still the same 50psi and idle problem. 🫠 I can also hear each of injector's solenoids running when I put a screw driver to it and have the other end to my ear. I might get a noid light just to confirm pulsasion but yeah, very strange that both fuel rails and injectors put out 50psi.  31-10-2024.csv I've attached it here. I started recording, then started the engine and let it idle with no throttle, then at the end I applied a little throttle and then stopped recording.    So, now idk. I'm going to see if swapping out the brand new R35 coils to my old splits fires will change anything. 🤷‍♂️
    • Hey mate, nice work on the car. Just a quick note, people generally don't like it when you use the forums to dump and run to advertise your YouTube content. If you're gonna stick around and join in the conversation then great, but if not this might not be the best place for you.
