looks like they had the IT sensor in a bucket of dry ice lol...
definately not right.... leave it till you have the 25 turbo on and get it tuned elsewhere, but dont drive it hard till then
https://www.sau.com.au/forums/topic/297071-r32/page/2/#findComment-4957002
what do u mean dont drive it hard then?
i have gtr injectors and rb25 turbo here waitin to go on how much is max psi on a rb25 turbo i herd they r good for around 18psi on a rb20 coz they dnt work em as hard as rb25s not sure i have herd mixed answers?
https://www.sau.com.au/forums/topic/297071-r32/page/2/#findComment-4957249
it is generally accepted not to go past 12/13 psi on the stock 25 turbo as the ceramic exhaust wheel can let go.
i ran mine @ 1 bar for a while, but there is no real performance gain over say 12.
by dont drive it hard i mean dont let it hit full boost untill you have got it on another dyno to check the afr's
if you lean it out hard @ 7k you'll be needing a new engine
https://www.sau.com.au/forums/topic/297071-r32/page/2/#findComment-4957958
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
