heya.
how is all just wondering i just finished doing a head on my r32skyline the head was serviced and had the 12 bent exhaust valves replaced done by fhyswick heads when i put it back together all wiring is on all vacuums are on all intercooler pipes are on and everything is tight when i tried starting it it pops and cranks but dsnt fire it has injector pulse, has fuel pressure has fuel flow, and has spark.
what im wondering if anybody has had this problem before and has any advice on what it can be any helpfull comments will be highly apprecieated it has been sitting for a couple of months now so do u think its worth while taking the plugs out and skirt some oil down the bores? also when i took the plugs out they didnt have any fuel on them? and it has pressure, flow and pulse.
thanks mark hope to hear back soon
https://www.sau.com.au/forums/topic/297088-rb20det-no-start-after-head/
oh i dunno never thought to plug the scan tool on lol when i was trying to crank it b4 it went KABANG straight out the exhaust so timing is out somehwere all coils are going to right place and i have all the wiring on the back of them right i drew a map b4 i took it all apart lol.
but would timing out cause the plugs to be dry when i take them out? it sounds like it has compression somewhere but dont have a compression tester to check. i also know there is one blue connecter under the collector assembly that i couldnt find to anything its right under the throttle body and just above the fuel rail.
also noticed the CAS has left to right adjust ment could that be cuase it if thats wrong?
had a look my exhaust cam nvr had a locating tang?
also the exhaust cam looks out a tooth so will redo that and will havta see if i can find a way to re align the cas again..
any idea what tht blue wiring connector could be?
CAS should have been marked when removed and put back exactly to same position (usually neutral position in dead center), in the wrong position can do nasty things like advancing the base timing (to the left) or retarding the base timing (to the right).. (if i remember left to right correctly). Timing will need to be checked each time the CAS is taken off.
You should be able to see where the tag broke off. Now all you need to do is visualise how the CAS would have aligned. The CAS also has a set of teeth to locate on the ex cam. By the sound of it, you are 1 tooth out on the CAS mounting position.
heya thanks all yea the exh cam is out by a tooth so when i get a puller to get the crank pulley of will put that back a tooth and get the cas on right cranking it one tooth out shoulnd effect the vavles should it? any ides on the connector will try get a pic of it im guessing the bang out the exuast was cause it was to advnced on the exhaust stroke?
heya guys got the 32 running today but the head seems heaps noisy like as in the cams are to tight i mean they did feel pretty tight when turning it over but didnt think much off it how tight are they cams suppose to feel? also its running pretty rough on start up what are some things i can check that would cause that after doing a head?
thanks mark
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
