Hi Guys,
Putting up my motorbike for sale to fund the cars for my wedding. :D
Anyhow specs
95 model Suzuki Across 53,000klms.
12months rego
4cyl 250cc (doesn't sound like a lawnmower, sound often mistaken for a 600cc).
Recently changed spark plugs, oil and had carby serviced.
New battery.
Bike has compartment where fuel tank is suppose to be, its to store your helmet in and other things (very handy).
Very fuel effecient,
New throttle slides/holders (common problem with these bikes).
Runs perfect.
I have had the bike for the last seven years, never ever a problem with it, extremely reliable.
extra info
Sport bike
Engine 4 Cylinders Four-stroke liquid-cooled DOHC
Top speed 170 - 180 km/h (110 mph)
Power 45 hp (34 kW)/ 14.500 rpm (crank)
Torque 25.5Nm @ 10.500 rpm
Transmission 6-speed constant mesh (1 down 5 up)
Suspension Front: Telescopic, coil spring oil damped
Rear: Link type, coil spring, oil damped, spring preload
Brakes Front: Dual piston single disc
Rear: Single piston disc
Tires Front: 110 170 17 54H
Rear: 140 170 17 66H
Wheelbase 1380 mm (54.3 in)
Dimensions L 2020 mm (79.5 in) W 695 mm (27.4 in) H 1120 mm (44.1 in)
Seat height 770 mm (30.3 in)
Weight 163 kg (359 Ibs) (dry), 183 kg (403 lbs) (wet)
Fuel capacity 12L including 2L reserve tank
Fuel Consumption is around 5L/100klms..
It is mostly known as a practical bike, due to its rear petrol tank and a fully enclosed helmet storage area where the petrol tank usually is. It is sometimes referred to as the 'handbag' due to its practicality. It is known to have reasonably light handling, good fuel economy, sufficient power, and a comfortable riding posture, making it a desirable first motorcycle for new riders or people who want to enter the sport bike scene. It is, however, approximately 20 kg heavier than most aluminum 250cc competitors due to its steel frame.
The Across is a remarkably powerful motorcycle for its engine size. It features a 4-stroke 248cc DOHC 16 valve 4 cylinder engine featuring a CDI unit and four carburettors. The engine revs up to 16500rpm and makes 45hp.
photo's
Please pm me or email me @ [email protected]
$2800
Sydney Western Suburbs
Cheers
Daniel
https://www.sau.com.au/forums/topic/297109-fs-suzuki-across-gsx250f-2800/
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
