easiest way to explain offset is picture the rim. Now picture a line down the very middle of the rim. Now picture the hub of the rim being forward of that centre line. That is + offset. Picture that hub being behind the centre line. That's - offsett.
To answer your wuestion the Drift Teks you are looking at will be inside your guards. You will not have to modify your guards at all.
If that is all your budget can afford then go that option. Or save up some more and keep on looking.
PM me what your budget is and I will do some homework and see what I can find for you. I can get some JAP wheels fairly cheap or other wheels with decent offsets and widths for you.
Brenton
Wow! I want this done to my guards, wonder how much a panel shop would charge?? if I could find a panel shop to do it.
old school racing (17x9 +24)
As you can see mine needs more low & lip/flare, GTR rims almost flush with guards, prolly stick out 2mm. I had to get the guards rolled at the rear, the fronts are standard and have never scrubbed (ride height = 350mm)
looks like youve got the s2 taillights as well.
THENIG - just some more low will sort it. and maybe a slight roll of the guards.
we run r33GTR rims on one of our race cars and with decent fitting tyres and they have stock guards.
the beauty with the dynamic camber on r32s is that as you go lower the more the wheel will tuck in.
ive just put some 17x9.5 work equips on the back of mine. ill put a pic up shortly and get the offset tomorow as i dont know what it is.
I didn't know there was a difference, maybe mine look different because I am using LED globes in all four tail lights.
Yeah car deff needs more low, been meaning to measure how much lower I can go for a while & get some new suspension (mine isn't height adjsutable) only thing is it scrapes coming out of my driveway as it is (Damm GTR lip), so can't go too low.
Also I have a pair of silver 'type m' side skirts at home that I have been considering putting on, but would let them go for the right price if anyone is interested.
whats the difference from s1 and s2 taillights ??
i had s2 tailights on my old car and def looks like them on yours
they have a crease in the middle that follows the line where the boot finishes (goes horizontally across)
the s1 are completly flat
edit: woops nick already answered
S2 lights have a line through the middle, lining up with the boot/bumper line. At least yours looks like it has those lights.
Nah its just the reflection in the picture, you had me going there for a while, had to go have a look at my car, it's 90' model, cloth trim not, I never noticed that the rear lights were different on a series 2, only noticed that some other 4 doors have a bigger skyline badge on the back.
  • 3 weeks later...
yeah the whole chassis base is the same, only the body is different
think its 7cm longer than the coupe, the main differences are from the front windscreen back ie. doors, boot, quarters, seats, carpet, etc
  • 3 weeks later...
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
