Thanks for the link..but........they all talk about carpet and vinyl cleaning. THe ceiling is a complete different area as the material is not plastic and liquids can get thru hence why i was asking if anyone had tried a specific product...
https://www.sau.com.au/forums/topic/297135-cleaning/#findComment-4949725
  • 2 months later...
dude, try G35Driver, there's a whole section on maintenance.
Only not sure if they have the same material, as i don't believe they got the suede/leather combo Japan did.
If not, there's also autopia.org
The best detailing site there is. If you know what the actual material is, I'll bet the house someone there knows how to clean it :-)
Finally, you can get some APC (All Purpose Cleaner) from places like Bunnings, and supermarkets, supercheap etc etc.
Most APC's have instructions on how much to mix to clean different surfaces. The one i use does everything from my leather lounge to grease in the engine bay.
With anything though, i would ALWAYS recommend you test on a hidden/hard to see area before going nuts :D
This is for both finer fabrics as well as the cars exterior.
Hope that helps.
https://www.sau.com.au/forums/topic/297135-cleaning/#findComment-5053837
hey guys off topic from the interior..and i didnt really want to start a new topic since this is "cleaning" anyways the question i wanted to ask is has anyone used or does use foam guns to clean there exterior or there V?
I use a pH neutral shampoo from Final Inspection. I don't have a problem with high pressure water if used to rinse only.
http://www.finalinspection.com.au/store/pr...;products_id=48
https://www.sau.com.au/forums/topic/297135-cleaning/#findComment-5054017
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
