Hello, I have my S2 RB25DET that I am tearing apart (after being imported) to bring everything up to new condition (or maybe a bit better ;) ). During the disassembly of the head, I noticed bumps in the exhaust ports right at the flange surface that go into the runners 3/4" or so. They seem like they might merely be a reinforcement of the exhaust stud holes, but it seems a bit overkill for such large bumps. Is it possible to port these all the way out? Is there perhaps a coolant jacket waiting to pounce on me if I try to remove them?
TIA,
Mark
Edited by WizardBlack
https://www.sau.com.au/forums/topic/297154-s2-rb25det-head-porting-question/
The only reason they are there is to match the hump that's in the exhaust manifold. Loose it. That's really the only major thing that needs done for a street port on an RB25/26 head other than polishing the bowls and matching up the intake ports.
Thank you for responding. I didn't even think of the factory exhaust manifold. Might I ask a few more questions?
In admiring the RB26 valvetrain, might you be able to install this into a 25 head?
Are the cam journal, height, etc. dimensions different?
How would the Tomei solid lifter setup in a 25 compare to a factory 26 valvetrain?
Does the Tomei lifter kit allow you to utilize 26 cams if you somehow deleted NVCS oil journals on the head?
The bottom line is I really want the solid lifter setup (like my previous engine; L28Et) of the 26; presuming that is most of the flow/rev difference between the Series 2 R33 RB25DET head and RB26DETT head.
Hey I have just pulled apart my car for a rb30 conversion and noticed the exhaust ports as well having the little bumps in the corners to direct the airflow for the standard manifold as well and decided to give the head a bit of a tidy up myself. I was wondering if anyone had any back to back results from a some minor port matching and polishing...I did do a search but only found a post where someone claimed that because of the restriction of the turbo being greater that it wouldn't make much of a difference
Wizard back can i ask what sort of mods you are doing? I think generally the stock 25 head is good for about 500rwhp standard with the appropriate turbo, if you are after considerably more its generally cheaper and easier to just buy a rb26 head, i dont think any of the rb26 parts from the head can be easily transferred to a rb25
Jarrod
Jarrod
I am after as much as I can get; just like anyone else. :-) In all seriousness, I am just tearing the entire engine apart (after importing) to clean it all up and rebuild. My car was at 2500 pounds (with a full tank) before switching from an L28Et to the RB25DET, so I'd imagine 400 whp sounds good. At the moment, this is just the basic stuff to get it into the car. I don't plan on taking the head back off when I upgrade the turbo, etc., so I wanted to get it fixed up now. When I have all the supporting stuff done, I was considering swapping to an RB26DETT. Getting a 26 head by itself is not cheap in my neck of the woods, unless I can coax an SAU member to export to me. :-) I could always export some Summit stuff in return (since I am in the same state with them). :-)
I suspect no one has a back to back comparison since you usually do much more than just that for a dyno check.
Are you in Ohio? I'm from Cleveland! 26 head casting flows the same as a 25 BTW. Only advantage is solid lifters, different cams, and the intake. You can do all of those aftermarket style, but the solid lifters are vastly over rated for a street car with mild cams and a smallish turbo IMHO. So are the ITB's.
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
