After i installed a Z32 into my S2 Stagea i decided to make up this little diagram for anyone else looking at the upgrade. This may also be the same as the S1 as i'm sure the AFM's are basically the same pink label MAF. The S2 wiring was almost identical to the S2 R33 wiring with the exception of cable colour. Also keep in mind you cant install a Z32 and run the engine without a tune.
Edited by QWK32
https://www.sau.com.au/forums/topic/297171-z32-upgrade-on-a-s2-stagea/
how much has all this cost you.
what will u gain? power and fuel maybe?? running an safc to tune it?
You can get a brand new Z32 for around $300. Then either shell out for a Tomei Z32 plug like I did, or use a VL AFM plug, I read they are the same.
There is no real gain to be had unless your chasing anything above 220kw. And then it's more of a must to chase the bigger power figure. The Z32 has more resolution than the stock AFM.
I'm using Nistune to tune for the Z32, but you can use a Safc.
No gain unless he's got a bigger turbo and his stock afm is on max voltage.
Stock afm's can only read up to a certain amount of airflow while the z32's can read more. Its just a supportive mod for bigger power really
Hey thanks Josh, looking to do this on my S2 soon and you just took all the hard work out!
Dave, installing a Z32 pretty much renders you car undriveable until you get a tune. Your running Nistune as well aren't you? its relatively easy to setup but from my experience from just doing this, its not as easy as changing the VQ map to suit the Z32. For me the fuel mixtures where off and needed to be adjusted.
  • 3 months later...
Thanks for the info - yes I'm running a Nistune as well; I just picked up a Z32 and so came back to this thread :) I was told it's a Tomei plug but the colours are different to yours. I will be getting a full tune when I install.
strange, although it is highly possible that tomei have just used different colour cables. just match up the pin id letters and you'll be fine. if your doing the install yourself make sure you can still get you car to the tuners as you wont be able to safely start and drive your car. what you could do is wire in the Z32 plug in parallel with the stock one, that way you can drive to the tuners on the stock AFM, then all the tuner has to do is swap the AFM and tune away.
Edited by QWK32
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
