Just installed a S-AFC II on my r33 gts-t, everything was ok except for the knock sensor. I followed the instructions correctly as far as i know and everything seems to read ok except for the knock sensor, it always sits on 0. I've tried both knock sensors on the ECU and i get the same result. Could it be that my knock sensors are stuffed? or have i just installed it wrong. Any help on the matter would be greatly appreciated.
https://www.sau.com.au/forums/topic/29719-knock-sensor-on-s-afc2/
what sort of knock readings do you get - and does anyone know what constitutes a knock?
I get 0 - 10 on a normal day and up to 20 on a hot day. I know the scale goes up to 200 on the safcII, so these can't be too bad. Would it be like to Power FC scale where above 60 means you are knocking?
Bad readings are when your talking 50+ over the IDLE figure. So if your getting say 20, and its a hot day, and you get 100 (via peak hold) after a WOT blast, then you have knocking. If the peak is only a lil more, then there is nothing to worry about.
Also dw about the idle figures as they rise with temp. NFI why tho. But the engine isnt knocking.
I just got mine installed today and i've just been for a drive and the knock goes upto about 10 which seems to be normal. But it takes quite a while for it to move though. I was driving a good 15mins before it moved off 0 on throttle.
However when i was at idle the knock would always read a higher value of 15-20.
Mine was installed today too and so far the highest I've seen is 9 at idle... During a WOT blast it sits on zero?
I've done the knk set a few times but it makes no diff?
Out of curiousity, what are everyones raw knock levels in the knk set menu? (ie 1550, and 3650)
Thanks
My knock in the knk set was about 50-60 when i first started the car then after driving it for a while it was upto about 70-90 odd.
what do u mean a WOT blast? In the monitoring menu on acceleration mine sat on 0 for a little while then it started to read figures. But the whole time it was working when the car was idle. Im sure its setup right, perhaps the engine needs to be at operation temp before it gives figures?
Who thought a knock sensor could be so confusing :D
WOT blast = Wide Open Throttle blast.
My knk set readings are pretty much identical: 50-60 to start with, 80-90 after a thrash.
At idle mines the same, between 4 and 10. But when flooring it, 0 all the way to redline? I was only driving for about 30 mins though... I will try it again tomorrow in the heat I guess...
At least I know it's not my crazy switch mod hey... :D
First of all, guys you shouldnt get huge numbers like 80 while idling. Otherwise your calibration is wrong. Go to www.apexi-usa.com to get the SAFC II manual! Btw u need the jap language pack, even tho there is no jap in the PDF? lol
Anyways, the higest ive seen is 20 at idle, but at cruising speeds, its zero which is most important. After a WOT blast i might get 25 or so, which indicates 25 - 20 = 5 knock counts during the WOT blast. Thats nothign to worry about. If its like 80 after the WOT blast, then pinging is at hand!
yep - me the same.
- raw figures are 50 - 60.
- idling sits on 0 - 10 on a cool day and maybe 10 - 25 on a 35 degree day.
- when accelerating, car is breathing in cool air from outside the engine bay and comes down to 0 (maybe 10 on a hot day)
it would be good though to speak to apexi and ask for some guidance on what level a knock is (ie 50 or 100?)
I know that Access Auto's in Vic is Apexi's Australian distributor and they have technicians that you can talk to if you bought the product in Australia (ie not imported from japan).
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
