Righto
Things I have that I don't need:
RB26 twin td06 20g turbo kit
what does it include?
manifold
turbos
oil lines with dash fitting and heat coatings
dump pipes
intercooler pipes
all silicone joiners and clamps
every nut and bolt to strap this mega power kit to your car
Please note that it's priced to sell
Manifold has no cracks in it and has not be welded since Trust made it
Note this kit comes with every farking nut and bolt you need to place it on your Gtr
I would recommend a re-build for both turbos just to be on the safe side (re- builds cost from 300 from a normal turbo joint to 500 from gcg)
I would also ceramic coat the manifold and housings if you buy it
Cost is around the 650 mark from Craved
I can arrange this if you want
Turbo are on the car and I'm happy to take you for a 1.8bar trip to show you that they are the shit and go harder than a 16 year old lad with his first porno
Turbos made 526rwkw at 20psi
Price $3500
The twins:
Front turbo
Rear turbo
Manifold with single 60mm Trust wastegate
Next we have a built auto R33 Gts gearbox, not sure what its rated at but runs fine behind the above turbo kit
What do you get?
R33 gearbox
Full manualised
Flex plate
3800 rpm stall converter
Oil cooler and line
Tail shaft (i dont need it)
A selection of R33 Gts gearbox controllers
B&N pro ratchet shifter installed and adjusted to the gear box
Basically every nut and bold to hammer it into your R33 and go drag racing
Bolt in and run some times!
Pete
Located in lower Blue Mountains Sydney
0448468884
dam slush box
What do you get?
R33 gearbox
Full manualised
Flex plate
Oil cooler and line
3k for the whole lot
video didnt work farken!
anyway ill punt up some other stuff
16 inch 5 stud waanabe rims (pair) 400
rear 17 inch disco rims 300
760cc injectors 600
trust gtr intercooler 4 inches thick 500
fancey flame painted rocker covers 200 exchange for some stockers
turbo kit will be comming off this weekend
dont be scared people
someone must want a lazy 800-1000hp kit for skidz!
lol
i also priced up some rebuild action and its 350 per turbo
ultimately if knowone buys the kit then ill have them rebuilt
so lets say 4k with rebuilt turbos
hammer time!
