hi guys im having a poblem with my S2 attessa 4wd system ,
i have just fitted 2 second hand tyres one on the front pass and
the other on the drivers rear . both tyres have 50% tread and
all 4 tyres are the same size 245/35/19 . now when i drive the car
the 4wd system is coming on under normal driving conditions
front torque gauge reads anywere between 5 kg/m - 10 kg/m
and the car feels as if it is surging . im thinking that maybe because
the tyres are actualy slightly a diffrent rolling dia so therefore the
attessa system sensors are telling it that one of the wheels are spinning
enough to engage the 4wd . im just wondering if anyone has come across
this problem before ??????, there was nothing wrong at all with the car
before the 2 tyres were fitted , and no one touched the car at all while the
tyres were fitted and the guys who fitted didnt break or damage anything
because i watched him like a hawk like i do with anyone who works on my stag
HAHAHA :D;):wacko::D any help will be very much apprciated thanks guys and girls ....
https://www.sau.com.au/forums/topic/297204-s2-4wd-problem/
Dude the diff rolling diameter is defs the prob. As a side not I noticed that the 4wd was kicking in more ofter with just lower tyre pressure (I know of others that this has happened to).
Also as kidafa said dont mix n match tyres from side to side on each axle. Not just for safety reasons but u can damage diffs etc by putting diff size tyres on the one axle.
https://www.sau.com.au/forums/topic/297204-s2-4wd-problem/#findComment-4950184
And risk damage to the 4wd system? Good advice!
plesae tell me how it is going to damage it ? the rear wheels wont be turning faster than the front so it wont send any drive to the front . and the overall difference wont be any greater than the difference between wheel speeds when driving around a corner. i put the space saver on the rear of mine and it was a flamin mongrel . sent like ten% to the front . unplugged the green wire and it was happy as
https://www.sau.com.au/forums/topic/297204-s2-4wd-problem/#findComment-4951837
thanks guys fo your help in conferming what i thought was the problem. i have changed the tyre that was the problem and it has fixed it . but i have booked the car in for 4 new tyres next week so my problem is now ALL GOOD thanks again eveyone who helped out !!!!
https://www.sau.com.au/forums/topic/297204-s2-4wd-problem/#findComment-4956136
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
