Hey everyone,
I know this has been covered in the DIY sections etc and I understand how easy it is.
But... I was wondering what different set ups people have used?
Whether it be using the factory CAI or cutting a hole in their shell etc...
I've previously had just cut 3" holes in my previous cars with abit of flaxi pipe etc.
But a few things/thoughts came up regarding my Stagea;
1, I would like it to stay as 'close' to legal as possible
2, I have a mate who has done a similar set up as the 'Pipe', but instead made a full
induction 'Scoop' type thing out of some colour bond. As he is still running a MAF, on the dyno
we noticed the air rushing in was upsettin the MAF when at idle. So in real time if he
were to idle at 100km/h he would be upsetting the MAF into thinking there was alot more air
coming in then there really was. In turn it was running rich.(Only at idle of course) ( ...If you follow? )
So my thought was to have some form on induction that would 'fill' an air box/heat shield inclosure
as apposed to blowing directly onto a pod. I have learnt the hard about Filters getting wet
as a result of having the induction pipe directly on the pod.
Thankyou
https://www.sau.com.au/forums/topic/297220-cold-air-induction/
Well my solution is to use the stock airbox and snorkel (with a highflow panel filter) together with the scoop on my air diverter plate and for extra flow a collecter behind the left hand headlight piped into the top of the airbox. Thta's what I had on my last RS4 but so far I haven't added the extra collecter - just relying on the stock airbox, snorkel and air diverter scoop.
not using a heatshield at the moment
simply a pod filter sucking in air from one of the intercooler holes underneath, and also from the standard snorkel air feed
hasnt been an issue so far, Im in adelaide where it's above 40degrees now and then and havent had an issue, 240kw too !
I was wondering what are the legal lines of cutting hole(s) into the shell?
My main thought regarding the cutting is not so much legal side of things... more
insurance concerns. If I was to have a front end, and they say that due to the hole(s)
the structural integrity was altered by me removing part of the shell?
Thus why I was investigating other needs/methods/styles etc...
I may add, for the moment I still retain the factory smic, but intend on using a 'turn flow' cooler,
so the piping will still follow the factory set up. So I wont be able to utilize the factory holes.
Edited by JDM_Spirit
Cutting the shell probably breaches legal concerns, your best bet is to switch to a factory GTR FMIC, and use the SMIC pipe holes for cold air.
On a non GTR front bar, you'll notice holes where the GTR cooler would go, likewise, in the shell of a nonturbo, you can see the circle there (just needs to be cut out), and the holes pre-drilled.
Got my ceffy with a K&N M's pod, but an exhaust leak quickly clogged it, given it a good clean a few times with no luck, for the time being I'm using a cold air snorkel and the top half of the stock air box, sitting over the pod...atleast directs some cold are onto it. Switching to FMIC and going to use flex pipe going down into the bumper where the SMIC was. Use some fly-wire type mesh on the front of the pipe, and run a few bends with some small drains to stop water and shit climbing up.
You don't need to cut holes. If you use the factory snorkle that wil supply enough air. If you want more there is plenty getting past the lh headlight. This applies whether you use the factory airbox or put a pod on and build an airbox around it.
The advantage of the stealth type fmic that quite a few of us have is that you can use the existing piping instead of cutting a hole and relocating the battery and either running piping across the top of your engine or getting a forward facing plenum.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
