Going off this thread HERE I decided to try these injectors out on my neo motor, Those of you with neo's will know how limited the injector choices are at a reasonable cost. sure you can buy drop in injectors but at around almost triple the cost of these... well the deka's start to make sense! At $420 for a set of 6 they are really cheap!
im not the first to give this a crack... urtwhistle provided some awesome info in that thread, however i thought i'd take pics along the way and post up a guide to help more people give it a go. I did do things differently and did not take the AAC valve off as you do not need to. just remove the whole top half of the manifold and put it aside.
first up. a list of what you'll need
hings you will need-
3 packs of bosch plugs (2 in each pack) ACA brand p/n BK402 $13.00 Trade per pack pack
2 spacers 20MM (wide) 12MM (thick) with a hole drilled 8.5MM $cheap
2 of M8x30 bolts
1x throttle body gasket (not needed if you don't break the 1 that is fitted) nissan P/N 16175-31U01
1x can of Lanoline spray
lots of spanners screw drivers, soldering iron, heat shrink, pipe cutter, pipe flarer
and most of all a huge amount of patience.
Start by removing your pipe work and any hoses that join top half of the manifold to other hoses, leave the aac valve on and you can even leave the throttle body on (i removed it as i put a R33 TB on instead of the NEO type) you'll then need a 12mm socket in 3/8 drive with wobble bar set, undo all the top bolts on the manifold and then get to the 3 long ones underneath the front and middle ones are easy to get to but the rear one can take some time. heres where having a selection of different lengths of wobble bar's help.
You should now have it looking like this. take note that as you pull the top half of the mani off that you have checked that all hoses connecting it have been removed. put aside along with gasket. get some tape and seal up the lower part of the manifold to ensure you dont drop shit in there. you can now see the fuel rail and injectors, start by removing the injector loom, this is quite easy to do, just pry out the plastic tabs and undo the plugs. put this aside as you'll be working on it later.
now undo the two 12mm bolts on either end of the rail. there are also two 10mm bolts holding the FPR on, once these are undone its ready to come out. now you can remove them by gently prying the rail and injectors away from the manifold or undoing the retaining clips and then prying the rail away from the injectors. since they have been in there for years they are going to be quite firm to remove. just be gentle and you'll be right. Keep the retaining clips as you will need them later.
Ok now you have everything out ready to modify. as you can see in the next pic its a comparison in size between the neo and the deka injectors... they are 12mm taller then stock, hence the need to space the rail up by 12mm. this is why the rail has to be modded to allow for clearance once the top part of the plenum goes back on.
Now its time to modify the injector loom, splice back the plastic sheathing to access the wires and then just do one plug at a time, the white wire with blue stripe is the common power feed positive so wire the red wire on the new plugs to this on all of them. use heat shrink and take your time to ensure a decent solder, last thing you want to do is have issues with the wiring. once all done you can then tape the loom back up.
Now you can modify the fuel rail. there is no need to cut any of the metal fuel lines like the link i posted to the other thread suggests, but you do need to undo the 10mm bolt in the centre of the rail which supports one of the lines, then cut off the tab on both the rail and the metal line. you then just bend the lines down a bit and then you can cable tie the main feed back in place to the side of the rail further down if you like. This is all you need to do, it will not fit without cutting that central tab however as it will foul. give the rail a quick clean and then get your new injectors and spray some Lanoline on the Oring and then install them into the rail with the plug's facing up. also install the retaining clip. Once you have all 6 in the rail, with clips on, its ready to go in.
you may have to remove a small metal bracket which is located at the rear of the intake manifold (lower section) which is held in place by a single 10mm bolt... i found it difficult to get the rail in place with this in the way.
spray the other end of the injector o rings with lanoline, line each one of them up and gently push the rail in. you'll feel them slide in quite easy. now that part is done you can bolt it up. Grab your spacers you had made and the longer bolts and bolt the rail in.
Nearly done, bolt the FPR back on with the two 10mm bolts, install the injector loom and then refit the manifold back on. make sure you check every single hose that you disconnected from the manifold is refitted. Also ensure the vac hoses are connected to the FPR's you can then turn the ign on to prime the fuel pump to check that there are no leaks, there shouldnt be :) if there is you have most likely damaged an Oring.
put all the pipe work back and and now you'll need to get the ECU retuned to suit... as it most certainly wont run too with with the current map.
I hope this helps people out there who would like to save a bit of money and run a decent sized injector... remember these babies are good for over 400 rwkw too!
Hi, any news/updates on this? I'm curious to know how are these injectors working with Nistune - thinking of buying a set for neo myself. What spray shape have you got - wide conical or narrow "pencil" style?
Thanks, Petros
  • 5 months later...
  • 4 weeks later...
Hey, thanks for the feedback Simon-R32, good to know they work properly. Did you reuse brown caps that are pressed on the nozzle side of stock injectors?
chef_stagea, I ordered my set through ballenger motorsports in US of A, got them for ~340USD shipped, took 15 days to receive.
Edited by Legionnaire
no i did not reuse the brown caps.. i just put the new injectors in with new orings and away i go :banana:
injectors are now handling 330 rwkw with ease... plenty head room left.
I got mine through a guy on the ford turbo forums. 420 delivered thro a trader.
  • 2 months later...
  • 3 months later...
  • 4 weeks later...
no probslems using PFC... the problem is they need to be tuned correctly thats all.
there are now 3/4 length deka's out for very similar price (set of 6 for 450 brand new for 60lb or 500 for 80lbs) which means you dont need to worry about raising the rail 12mm... easy!
btw i should also mention that these injectors (the 60lb veersions) handle 360 rwkw and still have headroom and thats on a 50/50 ethanol mix too. however i'm gonna run straight e85 and close to 400 rwkw so will be swapping them out for a set of 80lbs to be safe.
awesome awesome injector for the money..
  • 5 weeks later...
What is the part number for the 3/4 size injectors and where to get them from? I've checked the Ford XR6T Forums but the only thing I could find was an group buy thread which ended some time ago.
I also got this website from here which sell the injectors pretty cheap. http://www.bmotorspo...p/cPath/144_146
  • 1 month later...
+1
  • 9 months later...
When you re-tune the ecu after adding injectors, do you just go and select new injector size in cc and set latency only or you need to retune all the cells in each rpm band in the map?? Do you need to retune all the AFRs and timing too??
On a slightly different note, after substituting a Z32 to the original RB25 AFM, do I just select 'Z32' from the AFM drop down list and it is automatically calibrated??
I am running Nistune btw and if a 'retune' is as simple as I described above, then I could do this myself... (rubs hands in excitement..:nyaanyaa: )
  • 5 months later...
I bought 6 of these last week for $259 brand new off ebay USA! How cheap, now off to Bursons to look for EV14 to EV1 connector pigtails and 2X 12mm spacers with 8.5mm holes for the fuel rail...
Edited by rondofj
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
