As a result of my accident 2 of my rims were hammered.
One has been repaired so now i have 3 and the other doesnt look like it can be saved. The guy from aliance tryed as hard as he could :D
Does anyone know anyone that sell Enkei mags? Or could find the ones im after...
I am after either 1 or 2 Enkei RS Evolutions 17x7
Alternatively, I need a new set of mags.
In the meantime I would like to ask all the skyline guys out there if they have 2 mags laying around that I could borrow. Im after 2 17"s just so i can fix up/check the rest of the car. eg. suspension, body work, wheel alignment.
Thanks guys...
https://www.sau.com.au/forums/topic/29727-help-rims/
ohhh rep my man!! i am stuck mate i kinda need 17s by friday.... so i can get the front bar sprayed and blended to my car...
do you think i could borrow the 2 17s till i get the replacements (3 weeks hopefully less)....
i'll get you a couple of cartons for your trouble.... :(
ps. PM sent rep. :D
https://www.sau.com.au/forums/topic/29727-help-rims/#findComment-607371
HUGE!! thanks to rep, aka troy. :(:D
the wheels are on the car troy and they look bloody good. mind you they dont fit on the front because our brakes are too big and the offset is JUST to small... it just scrapes the NISSAN part of the brakes....
I took the car for a drive around the block and it doesnt seem to be that bad...i get the front bar back tommorow so that will be the real test because i'll hit 110km/h and then see whether it wobbles. @ the moment there is no movement only a slight lean to the right with the steering wheel...
I am getting a full wheel and alignment and balance done and then i will see what it is like...
the enkei saga is a bit more detailed and i'll let you know when i know anything for definate but im gonna start looking at a whole new set and have the enkei i have no as my drag wheels :( so sad, such a waste!!
https://www.sau.com.au/forums/topic/29727-help-rims/#findComment-611951
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
