Do you still have Hicas?? If not, the two hardlines that run under the car are perfect for weld on fittings and some dash 8 hose, in my application we use 2 044 pumps via a 4l surge tank to a twin entry fuel rail, sard fuel reg and 1 std line for return.
i have the hicas lock kit on my garage floor but what would i need weld on fittings for?? i thought it was just a surgey and two pumps in the boot running lines under the car to the twin entry rail.
hey guys im up to the stage of getting parts for my fuel system one thing im not sure about is do i use the old feed and return as both feeds to the rail and just run one return back from the reg to the surge tank?
Yes that works, mines like that.
If you do a search on this topic youll see threads with all kinds of into and pics etc
best thing to do for that number IMO is to have 2 x 044 s running from a surge tank with stock pump as a feed. Do a new return line to the surge tank, twin entry rail, easy as
Yes...mines also like that....good for 1000hp at the flywheel.
I use the stock feed and return as feeds and a -6 braided line as a return. 3 Bosch motorsport pumps (one gauze bottomed swimmer pump in tank and two 044's off the surge tank), 1000cc Blitz injectors, GReddy twin entry fuel rail and a Sard regulator.
Works well :P
Its good to see you fella's showing the faith. No point trying to re-invent the wheel :P .
Plus the fact it's cheaper and easier just to be a sheep (pity we don't have a emoticon for that, might have to find one :))
i didn't use the hicas lines for fuel lines instead
2 stainless lines feed and 1 return from gas tank all the way to the front
3 HKS 280L fuel pumps (intank)
2 inside the SARD 1L fuel tank and 1 in OEM fuel tank
aeromotive FRP
Tomei fuel rail
1000CC injectors
that is a flash setup, very nice with the gold fittings, gives it that japanese feel about it - nice gtr btw :P
yeah the sard surge tanks are good. they are basically like a mini fuel tank with inspection port on the top and you can mount your 'external' pumps inside it which does quieten them down a little and keeps them relatively cool too as they are sitting in fuel. it's a good way to go.
On the topic of fuel pumps, whats the max an 044 can handle?
I've set up my 044 intank pickup on my BNR34, looking to push around 380-400awkw on 2530s.
DiRTgarage, from memory you're making around 402awkw on 98 with 2530?
Any suggestions? Wasn't a lot of details on the article from HPi the GT-R special... haha!
a single 044 can handle the above quoted power BUT you need to take into consideration the integrity of that setup i.e. what if u get fuel surge which u are gauranteed with that sort of power & assoc. g-force?
what if that pumps fails for any unknown reason, the only warning you might get is 'pop'
also, running 400awkw the engine becomes much more reliant on fuel delivery
in other words, i think u would be mad to run a single fuel pump as many others would agree - walking on egg shells
Edited by Marko R1
With regards to fuel surge, i always keep the tank pretty full. Usually pour when there is about a 1/4 of a tank left. However, i guess i could always keep it above half in worse case scenerio?
If the pump fails, wouldnt the engine just turn off? I recall driving and the hose to my surge tank came lose, i couldnt accelerate no more and the car just gradually turned off? So what kind of pop are you talking about?
I've got 800cc sard injectors, sard fuel rail and sard FPR and its dual entry so i suppose i have done the fuel system oks, however, i used to have a sard surge tank though i had petrol smell in my car, is that common when using surge tanks? I found it quite wierd and couldnt take the air pollution inside the cabin!!!
i thought u would respond with "i'll keep the tank full" as i has similaar thoughts but then bit the bullet & ran a proper system
more than likely engine will just turn off but if you're pushing that much power you dont want to run lean at all - pop as in engine failure
i know what u mean about petrol smell in the car - ive had that before & apparently it boils down to the type of fuel hose as some are porous? correct me if im wrong but this is what i was told
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
