Hahahaha in my head, i was thinking yeah i'll keep the tank full, but the car drinks too much petrol. I always try and keep it full though only a short thrashing and petrol just sinks down to 3/4, so i am assuming it would be the same on track hahahaha!
I was thinking you meant engine failure, yeah i am not sure what will happen if it dies but have only had fuel problems once!
I see i see, i didn't know that. After i did the surge tank and got a EPA notice, i just took the surge tank out of my car. Couldnt stand the smell anymore, though if i knew how to run the tank without the smell i'd consider doing it again.
Either way, worse comes to worse i'll run one from underneath the car or something. See how i go with the 044 in tank and take my chances!
have u got a pic of your previous setup with surge tank?
i ran 320awkw with an intake 044, took it to the drag strip a no. of times & it seemed ok (ran pb 11.1) but then the piston ring land collapsed on no.2 (usually its 5 or 6 like my other engine lol)
anyway, was fuel surge the cause or age/wear & tear of factory piston...this remains a mystery to me
Here you go, i am not at home so i can't find the one that was installed in my car.
It was just sitting on the left corner of my car anyways..
320awkw and a PB of 11.1 is not bad! I have yet to run and i have 332awkw. You're scarying me with the fuel surge now!!! My new motor is nearly finished and i don't want to blow it again right away! Hahaha..
Do you think i can run 400awkw with HKS 2530s?
Hmmm best supporting mods... I dont know what Paul was running, maybe he'll tell us later
This is what i'm running...
HKS 2530s w/ HKS actuators
Tomei Valve Guide
Tomei Valve Springs TypeB
Tomei Procams 272/272 (in&ex 10.25lift)
Tomei Oil Pump w/ Tomei Baffles
Tomei Valve Lifters
Tomei 1mm Oversized Valves
CP Pistons 87mm
Eagle Rods
Sard 800cc, FPR and fuel rail
Bosch 044
Trust Power Evolution II exhaust (3.75")
ATS Twin Carbon Plate clutch..
Trust 115mm FMIC
Standard airbox w/ z32s
PowerFC
Maybe other missing mods... that i cant think of
Fingers crossed.. haha
Edited by destrukshn
paul likes talking specs, i reckon he pitches a tent half the time
head porting and high lift cams (which u have) made a big difference to my setup, i gained 43awkw on the same dyno although 1 was an rb26 @ 362awkw and now an rb30 @ 405awkw, same turbo setup
Hahaha guess we'll wait and see if he does pitch a tent and tell us what specs he was running when he had the 2530s setup.
It would be interesting...
I have run 350awkw before on Powertunes dyno on shootout mode at 20psi when i had Kakimoto 3.5" Full Mega N1+ Premium + Apexi Pods. Though i'm running a kakimoto regu 92z or something now, lost like 20kw :)
What turbos are you running with the 362awkw? Did you change your coilpacks? I was thinking RB30 at the time also, though didn't want a hassle too much with the 38mm height difference, though who knows i might do it with the spare engine if i am not happy with the overall performance...
GT-RS huh? I remember Paul writing somewhere the difference between the two wasnt that much with RB26 bottom end isnt that much?? :) maybe i am wrong?
You think coilpacks are necessary? Hahah i'm running 9.15mm lift on my current motor.
Hahaha maybe it does, or maybe it ran on a happy dyno :D
i think ive heard the same as well, not that much in it between the 2530 v's gtrs
apparently the coilpacks in the r32 are the better factory coilpacks - my rb30 is running factory coilpacks without a problem but i always think that these things are pushing 20yrs!
I'm surprised however you have an RB30 and you're only pushing 405awkw?
Paul must be running a monster in twoogle for it to run 500awkw on rb26 bottom end? Or happy dyno?
Hahaha jokess...
Yeah i was thinking of keeping it with the factory coilpacks, unless theyre breaking down or something then i'll change them...
Mine are only 10years old? 10years less than your R32 coilpacks hahahaha! not bad :)
there is a misconception with running the larger rb30 that it will give you more kw, BUT it will give u more nm...thats for sure :)
another comparo for you:
my rb26 made 700nm torque whereas my rb30 made 930nm of torque, overall power is much harder hitting & tractable, very hard to explain until u actually jump in an rb30 (chalk & cheese in terms of driveability). the new vg38dett in the r35gtr also supported my decision making to increase capacity.
i could have taken the path of running a t51r snail but i wanted a strong street setup with aggressive midrange as well as wanting that standard look to keep the law happy :D
paul is running a t51r with the larger t62 housing - its a farken donkey of all donkeys turbo!
i'd keep your coilpacks unless there is a benefit of running splitfires which im unaware of.
On the topic of fuel pumps, whats the max an 044 can handle?
I've set up my 044 intank pickup on my BNR34, looking to push around 380-400awkw on 2530s.
DiRTgarage, from memory you're making around 402awkw on 98 with 2530?
Any suggestions? Wasn't a lot of details on the article from HPi the GT-R special... haha!
Plenty of people here in Vic making 380rwkw are using a Nismo intake pump in GTR's.
No surge tank, no fancy external pumps, just a good old drop in replacement that works 100% perfect.
These are circuit cars, so if they don't have issues you'll be right.
Without a doubt the best pump on the market!
I made 340rwkw on E85 with just the Nismo intank.
With needing approx 30% more E85 to make that power over 98, the Nismo pump certainly punches well above its weight.
Now the car has a fuel system to support well over 800hp, ill get there one day lol
Same here, my car used to make low 400rwkw with just a Nismo in tank pump too :)
I now use it as a feeder for the surge tank and 2x044.
bingo! i also have a similar setup but with an 044 intank & 2 044's running off my surge tank
destrukshn, are u running a dual entry fuel rail? if so, it is a nice setup to have an 044 feeding each end :)
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
