Hey guys, I just have a couple of questions so i'll just bunch them up in the one post.
1. My clutch has developed a sqeak. I've never had a car have a sqeaky clutch before so whats the cause, and possible solution to my problem here? It only sqeaks when I depress/release the clutch.
2. After having the airconditioner on, and then switching too just the fan, there is a really bad smell (sorta smells like stagnant or stale water). It goes away after a while or when you put the aircon back on. Possible cause and solution (apart from buying an airfreshner :D)?
Its a 95 r33 gts-t by the way.
Any help will be muchly appriciated :D
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/
thanks for the replies. i thought it might be the pedal at first, but thought i'd get some opinions on what else it could be.
don't smoke, so thats not the problem (re: aircon) both my cars do it, the skyline is worse than my liberty though. i will have a search for the spray stuff
any idea on what it was called?
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-608515
Turn the air con on and get some air freshener and spray it down under the dash somewhere near the air intakes it sucks the spray through the system.Presto nice smelly air.
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-608584
Don't know what it's called, but it's been covered at least once on these forums - so if you search for it it should come up.
I also read a while back that a squeak coming from under the car when you press the clutch in could be either the slave cylinder, the arm / fork thing, or the thrust bearing. I get it myself, and my thrust bearing squeaks and whirrs, and I figure the only real way to check that and the rest of the things that could be wrong is to drop the gearbox and do a proper job. Which is exactly why I'll not be worried about it until I need a new clutch :) I'm a little concerned about spraying WD40 anywhere around my slave cylinder / bellhousing sort of area.
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-609006
Thanks for all the help. I went to the local aircon place and purchased a bottle of anti baterial spray with 'special trade secret blend' lol cost $16 and its made by a company called 'earth innovas', if anyone is interested.
just spray it in your intake vents. too easy...car now smells like a hospital, but at least it doesn't stink lol
just another question that arised whilst spraying this stuff into my intake vents...any ideas on why the drivers side vent is fully open, yet the passenger side vent only has tiny holes and is mostly covered????? (these are the vents at the bottom of your windshield under your wipers.)
because i looked on my liberty and it has symetric vents, just seemed odd to me to have one side open and the other with little holes.
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-611961
It could have something to do with the demister.
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-612035
Also with the clutch out it makes a constant squeeking/ratteling noise...
this is the throw out bearing, dont worry about it much it just becomes annoying.
as for the other squeaks most of them are you pedals, like mentioned spraying wd40 on the springs and hindges usually works
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-612079
i dont know the technicalities of it but i had a squeaky clutch also and it wasn't the pedal. I had my car at nissan for a service and asked them to look at it.
They said it was a known problem and somehow adjusted it and got rid of the sqeak and did it for no charge.
sorry for being so vague!
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-612096
I was under the car the other day, and the noise is comming from, i think it is the slave cyclinder. The little metal thing on the bottom of the box... When i hold the leaver thing the noise goes away.. I sprayed it with wd40 but it didnt do nethn.. i think i need grease..
Least i know now its not realy harmful.
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-612278
the noise is actually coming from the bearing that is attached to the metal arm that is coming out of the bell housing. its a bearing that sits against your clutch and as the clutch spins so does the bearing, sometimes they get noisy but nothing to worry about. you could replace it but its not worth it unless your going to change your clutch because the whole gearbox will have to come out
the slave clyinder is the part that pushes the arm that disingages your cluch
so if your clutch is pressed in (disingaged the clutch) the bearing wont spin hence it wont make a noises
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-612401
Had this problem myself and was fairly easy to fix.
Get under the car and position yourself near the slave cylinder.
Undo the two bolts holding the Slave Cyl on and remove remove it from the bellhousing. Then remove the rubber seal that the clutch fork protrudes thru. Peer into the hole with a small torch and you will see the pivot post at the rear of the clutch fork a few centimeters inside the cavity.
Next just gently push the fork away from the pivot post (it's held in place by a spring) and gently spray some spray grease into the pivot joint using an extension nozzle (i used white lithium spray grease).
Put it all back together.
The squeaky clutch and that rattle at idle will be cured!
https://www.sau.com.au/forums/topic/29728-sqeaky-clutch/#findComment-613841
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
    • I presume it would take more than just slapping a big modern catalyst on the exhaust? It's interesting though, looking at the old sales brochures and listings it does not mention anything about emissions. No one cared.
    • Yeh nice, looks like their part of keep it reet? Will have to swing past. I'd much prefer someone actually look at my car and custom make a part, then get a generic part online and hope it works.
