Stuff Need To Sell!
The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
Editting as I hit post to soon, and this will lock out otherwise.
Think ill be going hunting for bad earths and might just replace the alternator for shits n gigs as its an LS alternator but only about 5 years old with very minimal use in that 5 years.
more sensors sounds very smart least you never doubt a single sensor. it has dropped about 10 psi at a 5k rpm low load shift but regains it in a normal way, not showing like a quick blip on the chart but more presenting as like a build up of pressure again. unlike the 8k rpm high load shift which shows a quick up and down spike on the oiul pressure graph.
its certainly looking like a power issue now which im all for so i can test turn the limit off for the upcoming track day i was hoping to make ahahahah
