Item Summary: rb20det complete motor, gear box, loom and power fc
Condition: Used
Reason for Selling: putting a 26/30 in my car
Asking Price: 2500 Ono possibly seperate or swaps for rego'd car or 250cc road bike
Delivery Methods: PickUp or post
Contact Info: pm here or 0432470609
Extra Information:
hey guys i am selling my rb20det out of my 32, its been running real sweet for the last 2 yrs, it comes with every thing except for injectors, will get pics up tomorrow, can post if need be, still in car if u want to hear running or even take it for a drive, its got about 300hp (not 100% sure on that last dynoed it had 278hp but has had tune up since)
remember u get it all = turbo, intake, inlet, gear box, loom, 26 power fc modded for 20 by professional's and motor
was tuned by Johno Pace (mafia on here) ask him how well it goes if u want
would really like $2500 for it all not willing to go much more lower or will trade for a cheap car
thanks blocka
call or txt 0432470609
Separate FC from motor?
How much?
$1000?
yeah bud $1000 if some one else buys the motor and box and loom
ok everyone change of plans engine comes wih every thing now so injectors are included and they are 700cc sards
so for everything for a straight drop in and fire up set up $3000 or swap for a rego'd car or 250cc road bike
Edited by blockasR32
Ok considering seperating, if I get enough interest the fc will go to R32Abuser so who wnts the engine and box
Ok guys considering seperating but need some interest in it
PFC- $1000 or $1200 with loom
Engine- $1500 with injectors, turbo the works and standard coilpacks
Gearbox- $500
prices aren't 100% firm
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
