hey guys i need some help im looking at putting a t51r with a .91rear housing its for a wrx that is now 2.6 ltr. i thought i would come over here and ask the skyline boys as i dont have any experience with these tubos.
the current engine set up is
wet sleeved 2.6ltr block
mahle pistons
par 1500hp rods
acl race bearings
2.5 crank
o-ringed block and heads
copper head gaskets
14mm headstuds
ported heads
1mm o/s inlet and exsurst valves
brian crower springs
wade 300deg cams
extractors
indy blue injectors
2x044 pumps
half inch fuel lines
ect list goes on
fuel - e85
the curent turbo i have is a gt35/66r it has 66mm front wheel, .80 front cover and a 1.06 rear housing and this turbo is to small and is on full boost just after 4000rpm but the the turbo has now spun the blade on the sharft and stuffed the front blade bent the sharft and stuffed the front bearing in it. and its going to cost 1200 to fix it, the turbo has now even done 200kms
so i was looking at a garrett t51r with a .91 rear housing do you guys think this will be to laggy on my set up ? im not to worred if it is abit because im running a nitrous kit as well
and i forgot to mention it has a built auto in it now with a 4,200 stall coverter
your help would be appreciated alot.
cheers
Edited by Lee586
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/
From the research etc. that we have done and advice given by people in the industry, the 0.91 rear will be laggier than the 1.01 or 1.05 rear due to it's TV (T6) flange which causes a huge pressure drop before entering the turbine. You are better off with the 1.01 rear that has a T4 flange. Considering there are none available or none have been sold in Australia, your options would be to buy it from the states or get the TA (1.05 A/R) rear milled to the T4 bolt pattern as they are only a mm or so different in their bolt pattern.
I would expect to see 1 bar of boost on the 1.01 rear at approx 5000rpm on a built EJ @ 2.6L.
And where did you get a GT3566R? Never heard of or seen one. I think you are probably referring to a GT3582R. Garrett don't make a compressor with an exducer of 66mm. that would be almost like taking the compressor off the GT3582 and putting one on from a GT2871....but smaller
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950550
thanks for your help the t51r i was going to buy from turbologic he said it was a t4 flage witht he .91 rear so im not sure, the 66r i have was custom built by gcg it uses the same shafts and rear blade as the 35r but the front wheel is 66mm and has a .80 front cover with a 1.06 t3 rear housing
when looking for turbos it gets compacated the guy said he can only get the t51r in a .91 and a 1.05 rear housing with a t4 flange
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950574
No, the GT51R comes in a 0.91 T6 (TV Flange) 1.01 T4 or 1.05 TA Flange. It also comes in others but not sure on those. I could find out if you really wanted the info on the bigger sizes.
The GCG turbo you are talking about is probably a T04Z compressor on the GT35R core. Very inefficient.
And Garrett would call it a GT3584R because it's the exducer that determines the last two digits. GCG like to be backwards.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950596
yeah they recon it was a to4z equverlent but it was really inerficent like you said, the turbo it a complete pieace of shit in my opinion.
what other turbos would you recomend for me as soming that might get decent boost around 4,800-5000.
i was also looking at the turbonetics gtk1000 it has a 76front blade 68rear blade with a .96 t4 rear housing
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950615
How much hp are you chasing is probably the more appropriate question?
If you want 600-700hp at the wheels then pick a GT3788 or GT4088. You should see 1 bar at 3800-4000 on the 37 and about 4200-4500 on the 40. If you want 700-800hp then you will need minimum GT42 or above. Things start to get complicated after that and a lot of questions need to be asked.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950627
the auto draged about 50kw off at the wheels but i want about 400kw@wheels with the auto, and need somthing effecent enough to run 35psi
then will put a 150hp shot of nitrous ontop of that so there is a big chance it could go 500kw
we made 411rwkw with a cheap GT40 (v band rear 1.0) ($1300) through an auto on a1jz (2.5litre) at 22psi.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4951896
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
