Hiya all,
I'll be picking up a manual AWD box for the stagea this week sometime, together with all the additional bits I need for the swap. Just wondering if anyone has done this kind of swap before, and if they would have any suitable premises for such work. My house is under construction for a house extension, so there is no room for me to do it there ... and I think Tracy has banned me from doing such work at home :D
I'm no stranger to working on cars, but wouldn't mind a hand for ease of work and a speedy job ... plus its always best ofr another set of eyes to be going over the job. Not too keen on paying a workshop to do it ... but not keen on doing it alone ... so aiming for somewhere in the middle!
There's a carton of beer in it for any assistance. I'm keen to start (and finish) the swap not this weekend, but the next. 33 is sold, so the Stag is my daily.
https://www.sau.com.au/forums/topic/297339-help-with-gearbox-swap/
  • Replies 44
You'd be handy if you had an engine hoist :(
Should be picking up the box and bits tomorrow arvo ... then I can see how much trouble I've gotten myself into. :P
you after a engine crane ruby ? i have one here at home if ya need to borrow one
Hmm, I won't say no if you do have one. I'll hunt for a venue to do the swap, and if they do not have one handy I might just hit you up for it!
Figured I might just pull the engine and box out complete, swap boxes, double check bolt on bits on and around the engine, then put everything back in ... to eliminate the need for a hoist and multiple persons to hoist the box in place.
:huh:
the 5th and 6th of December? I can always come round to talk shit, and hand you spanners. Thats all ill be good for
Drop the engine and box out...
Far out! Not how I'd be doing it but shall be interesting. Perhaps someone can be there to take photos and note the process for another manual conversion SAUSA style?
I could help out, but i would only be good at those 2 things :down:, would like to come along anyway to see how its done, and to learn.
I need to replace the gasket between the turbo and dump pipe anyway, and a few other things (CV boots etc) ... so its just easier to do it all in one hit and with the engine out. Just haven't done this amount of work in one go in over 5 years.
I'll be sure to take pics and notes along the way :down:
I bought the GTR box and Nismo clutch kit and Nismo flywheel for some of the coin ... plus I'm happy with the BBS rims for now >_<
Might have a workshop lined up with Lukey boy. During the week, I'll see who would like to lend a hand and we'll get a bbq happening ... thats if Luke doesn't mind the extra company.
:blink:
Okay its all set. I've arranged to use premises for the swap kindly provided by Luke in the North Plympton area.
Can I have some volunteers to help for a few hours, talk shit and drink some of my beer? I'll mostly need you to help remove the auto trans and then fit in the manual box ... prob 4 peeps all up!
id give ya a hand Ruby but i have a feeling im gonna have my hands tied
with another certain car thats giving me hemorrhoids lol
Luke, any chance i may be able to borrow the cltuch alignment tool?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
