I found the issue with the factory boost gauge bouncing or not working at all. If you open the sender unit, dont remove the board, just solder the three pins (at the top of pic) that run to the plug underneath and youre done. Literally a 2 minute fix.
  • Like 1
https://www.sau.com.au/forums/topic/297345-m35-factory-boost-gauge-repair/
So is that the issue then - just a bad contact on some of the solder points?
Excuse my newbie-ness, but where is this sender unit located? I have done a bit of soldering in high school but my brother-in-law is an electronics tech so I'll get him to do the actual fix up...
Is it easy to get to? or is it a case of 30 mins getting to the part, and 2 minutes to fix it...?
Steve, it is the black, roundish sensor that sits to the left of the rubber bend part of the intercooler pipe
Just unscrew from bracket, remove bottom hose and pop the tabs on each of the four sides.
That is him, in the middle.
Edited by iamhe77
Thanks mate :P
I think the ecu sensor is the one before the blow off valve you can see in the top right of the pic.
Fix it yourself, its just a dab with the iron. Easy. :P
Edited by scotty nm35
its funny, RX and ARX dont have boost gauges yet they still have the sensor lol
is it a 0-5v sensor? might be able to use that instead of installing another one for an aftermarket gauge.
digital boost readout anyone? :P
  • 2 years later...
  • 3 years later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
