Great tip, if you don't have a soldering iron and want to quick fix get a small clean blade and clean around the edges of the solder where it contacts the pcb. That's where mine had the crud built up and it worked a treat after, I noticed their is two small pots on the pcb also, look to be voltage regulators, anybody know for sure? This could be tweaked to help prevent future failure.
Zelda
  • Like 1
Cleaning a dry solder joint won't repair the connection, you need to heat the solder, remove it using a solder sucker or wick and replace with new solder. It's not like soldering irons are expensive, they are much cheaper than a second hand sensor.
Tweaking the pots will likely make the gauge read wrong, then it's useless.
  • Like 2
Look at the pic; the three pins, in a straight line at the very top of shot.
They are the ones that need resoldering.
re-solder the 3 pins in red color
thanks guys! are those 3 pins connected to some wires or the chip? cause when you say resolder that 3 pins. what are you actually doing to it? heat them up so they can connect back to the wires/chip or?
p.s. sorry... real beginner here.
Yes, heat them up then let them re-connect. I just repaired mine because intermittent not working problem.
  • Like 1
Zelda
This is probably the dumbest advice I have ever read on here.. please atleast have some knowledge in anything before recommending how people fix their cars.
Thanks for the insult brick.
I'm an electrician by trade. If you didn't know, copper actually oxidises and by gently removing this with a clean blade your essentially cleaning the contact to the pcb.
Sorry that my common sense insulted you ?
It's not necessarily a dry solder joint, as you have all found the re soldering of the connections only lasts so long.. This is probably due to over voltage or a lack of it, solder tends to add resistance to a join creating a hot spot causing the actual connection to fail before anything else, hence the reason for putting voltage pots in the pcb to compensate for added or less resistance in the total circuit ( impedance or Z )
If you are an electrician you should know better and maybe go back to tafe. . I am an electronic technician by trade so I also know about pcbs etc. Firstly you are correct in saying that it may help, but it won't fix the issue. All it may do is minimize the intermittent issue you are having. That being said if you drive a long a bumpy street you will most likely have signal drop in and out as the joint moves around. Secondly the issue will return quickly. For the cost of a $5 soldering iron why wouldn't you just actually fix it.
Thirdly you were recommending people adjust the pots on the pcb. This is the really dumb thing. It is obvious that they would be set to the correct settings from factory. And adjusting them will only make it read incorrect.
So opt simply your original recommendation will not fix the problem and then when the person adjusts the pots they will ruin it all together so I stand by what I said in it being the dumbest post ever.
That is exactly what a dry solder joint is. Just resolder it like Scotty has said and it is fixed.
As an electronics tech that worked on PCB level repair myself, I am entirely confident it is a dry solder joint that needs fresh solder for repair, which I have fixed on a dozen cars at least.
Josh 1 - Zach 0 :P
  • Like 1
Lol yes Scott. What's causing this dry solder joint? Over or under voltage.
Josh I'm not telling people to adjust their pots I was asking if somebody like yourself who apparently knows everything if they had a better idea on how to find out for sure before tweaking it. ?
All I'm saying is cleaning the joins will also work if you don't have a soldering iron( which I do, just didn't need it) Sure may not be as good. The boost gauge is so crappy anyway I'm not sure why you have to get so defensive about it. It's only good for 1bar.
Just another option guys ?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
