Great tip, if you don't have a soldering iron and want to quick fix get a small clean blade and clean around the edges of the solder where it contacts the pcb. That's where mine had the crud built up and it worked a treat after, I noticed their is two small pots on the pcb also, look to be voltage regulators, anybody know for sure? This could be tweaked to help prevent future failure.
Zelda
  • Like 1
Cleaning a dry solder joint won't repair the connection, you need to heat the solder, remove it using a solder sucker or wick and replace with new solder. It's not like soldering irons are expensive, they are much cheaper than a second hand sensor.
Tweaking the pots will likely make the gauge read wrong, then it's useless.
  • Like 2
Look at the pic; the three pins, in a straight line at the very top of shot.
They are the ones that need resoldering.
re-solder the 3 pins in red color
thanks guys! are those 3 pins connected to some wires or the chip? cause when you say resolder that 3 pins. what are you actually doing to it? heat them up so they can connect back to the wires/chip or?
p.s. sorry... real beginner here.
Yes, heat them up then let them re-connect. I just repaired mine because intermittent not working problem.
  • Like 1
Zelda
This is probably the dumbest advice I have ever read on here.. please atleast have some knowledge in anything before recommending how people fix their cars.
Thanks for the insult brick.
I'm an electrician by trade. If you didn't know, copper actually oxidises and by gently removing this with a clean blade your essentially cleaning the contact to the pcb.
Sorry that my common sense insulted you ?
It's not necessarily a dry solder joint, as you have all found the re soldering of the connections only lasts so long.. This is probably due to over voltage or a lack of it, solder tends to add resistance to a join creating a hot spot causing the actual connection to fail before anything else, hence the reason for putting voltage pots in the pcb to compensate for added or less resistance in the total circuit ( impedance or Z )
If you are an electrician you should know better and maybe go back to tafe. . I am an electronic technician by trade so I also know about pcbs etc. Firstly you are correct in saying that it may help, but it won't fix the issue. All it may do is minimize the intermittent issue you are having. That being said if you drive a long a bumpy street you will most likely have signal drop in and out as the joint moves around. Secondly the issue will return quickly. For the cost of a $5 soldering iron why wouldn't you just actually fix it.
Thirdly you were recommending people adjust the pots on the pcb. This is the really dumb thing. It is obvious that they would be set to the correct settings from factory. And adjusting them will only make it read incorrect.
So opt simply your original recommendation will not fix the problem and then when the person adjusts the pots they will ruin it all together so I stand by what I said in it being the dumbest post ever.
That is exactly what a dry solder joint is. Just resolder it like Scotty has said and it is fixed.
As an electronics tech that worked on PCB level repair myself, I am entirely confident it is a dry solder joint that needs fresh solder for repair, which I have fixed on a dozen cars at least.
Josh 1 - Zach 0 :P
  • Like 1
Lol yes Scott. What's causing this dry solder joint? Over or under voltage.
Josh I'm not telling people to adjust their pots I was asking if somebody like yourself who apparently knows everything if they had a better idea on how to find out for sure before tweaking it. ?
All I'm saying is cleaning the joins will also work if you don't have a soldering iron( which I do, just didn't need it) Sure may not be as good. The boost gauge is so crappy anyway I'm not sure why you have to get so defensive about it. It's only good for 1bar.
Just another option guys ?
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
