I've been having an intermittent problem with the gauge so went to tackle this job today armed with my soldering iron. Unit looked good so followed the vac hose back to the plenum... found my problem:
No soldering required today! :P
  • 1 year later...
On 4/19/2015 at 11:06 AM, joshm35 said:
Just remove the unreliable oem gauge and problem solved. Thread closed
Anyone got one of these unreliable OEM boost senders?
I haz gauges that have no sender...  Plug and loom would be handy too...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
